How to turn off ABS?
The car is a 1994 Honda Accord, and since no one can tell what's going on in this post:
https://honda-tech.com/zerothread?id=499141
I was wondering if someone could tell me how to turn off ABS all together and see if that fixes the problem, at least intermittently.
TIA
TIA
Re: How to turn off ABS? (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda »</TD></TR><TR><TD CLASS="quote">pull the abs fuse ?? i just cant see how the abs can cause the other problems tho.... </TD></TR></TABLE>
Yea, pull out the fuses in the ABS fuse box.
Where is the ABS fuse located?
Also, I agree, it's doubtful that the rest of the problems such as the speedo shutting on and off for a split second is probably not caused by the ASB problem (although I know for a fact that there is a problem with ABS due to the symptoms prior to the speedo problem taking place). Someone told me to check for corrosion on the battery clamps, so I will be replacing those tonight to see if it fixes anything.
Re: How to turn off ABS? (dynamo)
It is located on the passanger side under the hood on the front side of the shock/strut tower. All you have to do is take out the one Main ABS Fuse (I think it is green with a clear top if I remember right and a 30 or 40 Amp Fuse) which is screwed down by two screws. I have done this to my abs once when My ABS Unit went Bad.
