How to test/fix fuel pressure problem. 93 Accord - Honda-Tech
Old 12-02-2010, 07:50 AM   #1
Icon6 How to test/fix fuel pressure problem. 93 Accord
So, when my car sits for a set amount of time (six, seven hours) it has a rough time starting and I have to hold down the pedal to build back up the gas pressure.
How exactly do you test for these things? I've replaced a hose leading straight to the engine from the fuel system that had a cut in it, and I will say that that particular piece that connects the hose to the engine does seem loose but I don't have the experience to know if that is the issue.
Maybe also someone could suggest a bonding agent for that?
dlenoxx is offline   Reply With Quote
Old 12-02-2010, 10:56 AM   #2
Default Re: How to test/fix fuel pressure problem. 93 Accord
Pull your injectors out and see if they are clogged. Though this sounds more like an airflow issue to me. Fuel pressure problems will generally cause the engine to lean out towards the higher RPMs.
When you turn the ignition on can you hear the fuel pump priming?
chikin pickle is offline   Reply With Quote
Old 12-05-2010, 10:44 PM   #3
Yes, and in fact I put a new fuel pump in it a while back.
I wouldn't doubt it on the air flow part, though. My engine does seem to cough and sputter quite a bit when getting started.
Old 12-08-2010, 06:28 AM   #4
Alright, so let's say that there was a clog some where in my exhaust system- would it cause this? Namely, junk or water that has gotten into my catalytic converter.
Old 12-08-2010, 08:02 AM   #5
GhostAccord's Avatar
Holding down your gas peddle while trying to start the engine does not add fuel. Fuel injected vehicles do not work like carbureted ones.
Yes a clog in your cat can cause a rough start but you would also have no power after the vehicle was running. Going up hills this lack of power would be very noticeable. Your catalytic converter would probably start to glow red hot if it were clogged that badly.
I would take a guess that you may have an ignition issue. When was the last time you changed your distributor cap, rotor, spark plug wires and spark plugs? It could also be your ignitor or coil starting to go bad. There are tests that you can perform to check the coil and ignitor. Don't just go replacing them.
GhostAccord is offline   Reply With Quote
Testing fuel pressure regulator prodjay10 Honda CRX / EF Civic (1988 - 1991) 1 07-02-2016 08:35 AM
2011 EX-L Fuel Tank Problem RussBarnes Honda Accord & Crosstour (2003 - Current) 6 03-22-2015 04:36 PM
GSR Starts really bad now after replacing fuel line from filter to fuel rail, advice? OH_1fstgsr Acura Integra 11 05-03-2010 04:27 PM
Where to buy a fuel pressure test gauge billyrusa Honda Accord (1990 - 2002) 0 06-10-2009 07:02 AM
HELP!! Hybrid won't statrt!! Ehron Hybrid / Engine Swaps 17 02-21-2003 08:27 PM
Tags
93, accord, acura, cat, check, converter, dlenoxx, fix, fuel, honda, pressure, red, test, tl, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
