how to subdue the "rice sound" - Honda-Tech
Old 10-09-2004, 07:04 PM   #1
ATX96coupe's Avatar
Default how to subdue the "rice sound"
alrighty, i've got a 96 coupe (f22b1) and i had a question about how to subdue the buzzing rice sound that comes from my exhaust pipe. the engine note that i hear from the inside of the car sounds awesome, but if youre on the outside, you can hear a real bad buzzing sound, and i hate it. alright here's the set up:
stock exhaust manifold---------cat------(replaced factory resonator with straight pipe--------magnaflow muffler (the round body flow through one with a nice tip welded to it).
by the way its using all the stock piping and that rear muffler is welded in place of the stock one.
alright, if i replace that straight pipe with some sort of glasspack (i think the stock resonator is a fiberglass one anyway) or any sort of universal flow-through muffler, ya'll think that would do its part in helping get a "not so rice" sound? any imput would help. thanks
Mark
ATX96coupe is offline   Reply With Quote
Old 10-09-2004, 07:07 PM   #2
sj993's Avatar
Default Re: how to subdue the "rice sound" (ATX96coupe)
Well I'd get a cat-back exhaust that is relatively quiet like Apexi or something to that effect. Of course nothing is as quiet as stock.
sj993 is offline   Reply With Quote
Old 10-09-2004, 07:21 PM   #3
ATX96coupe's Avatar
Default Re: how to subdue the "rice sound" (sj993)
yeah that would all be gravy and everything, except that was not what i was asking. i was asking for an inexpensive solution for this, and if what i proposed was a good solution or not. i dont wnana spend 400 dollars or more to get relatively the same sound as 20 dollars for a 24" glasspack(i know it wont sound the same but im talking about volume and getting rid of that rasp). thanks
Mark
Old 10-09-2004, 07:34 PM   #4
RUBZERK's Avatar
Remove the bottom side heat shield from your exhaust, part between the pipe & the ground
RUBZERK is offline   Reply With Quote
Old 10-09-2004, 07:43 PM   #5
Sublime95's Avatar
Default Re: how to subdue the "rice sound" (RUBZERK)
I believe a glasspack will amplify the sound. That sound comes with owning a Honda, personally it doesn't bother me. Most 4 cylinder engines make that sound. Maybe a silencer to put on your muffler?
Sublime95 is offline   Reply With Quote
Old 10-09-2004, 08:10 PM   #6
yeamans17's Avatar
Default Re: how to subdue the "rice sound" (Sublime95)
almost every time you throw a modified muffler onto a set of stock pipes your gonna get a ricy sound, i would just go with the cat back, it will sound much better
yeamans17 is offline   Reply With Quote
Old 10-09-2004, 08:23 PM   #7
ATX96coupe's Avatar
Default Re: how to subdue the "rice sound" (yeamans17)
so not even throwing something it that would work as a resonator would mellow it out? oh well, do you think it would hurt to spend 45 bucks on a moroso spiral flow muffler? it is like 18" long and it has baffles on the inside like motorcycle pipes that helps control sound but actually says doesnt increase backpressure at all. oh well, lots of stuff out there, i'll research a little bit
Mark
Old 10-09-2004, 09:30 PM   #8
Mark
There's your answer.
pyrojeff is offline   Reply With Quote
Exhaust leak? wafflecopter Honda Prelude 6 07-14-2015 06:42 PM
94 civic coupe muffler choosing help! JPRhome Honda Civic / Del Sol (1992 - 2000) 6 03-31-2014 09:42 PM
resonator\exhaust please help asap js7bla Honda Civic / Del Sol (1992 - 2000) 4 08-31-2013 12:57 AM
Tuning exhaust sound. danielm3 Welding / Fabrication 31 12-23-2011 09:46 PM
Friend created a cheap exhaust.....really nice sound. JD_B18CDX Honda Civic / Del Sol (1992 - 2000) 12 01-23-2002 06:09 PM
Tags
honda, muffler, rice, sound, subdue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
