Looking into fixin up my braking system any suggestions on certain brands to use?
Old 10-09-2004, 08:19 PM
lazyxazianxboi's Avatar
Default Looking into fixin up my braking system any suggestions on certain brands to use?
I'll be changing out the rotor for brembo blanks and aem pads and s/s lines from neuspeed.....and i wanted to change the type of fluid as well so any help would be great......thanks
Old 10-09-2004, 08:23 PM
madd's Avatar
Default Re: Looking into fixin up my braking system any suggestions on certain brands to use? (lazyxazianxbo
any good dot4 fluid dont get the cheap *** stuff....as far as brands im not sure. i bought some valvoline dot 4....i just grabbed it, but i dunno. have you thought about upgrading the the legend gs (2.3l) 2 piston calipers? you will need, i believe, a 23T bracket as the stock one will not work. you will then be able to use the 11" rotors.... also, you can do the 98-99 CL hub conversion so that you will have rotor over hub instead of hub over rotor...just some thoughts while your down there.... (i know this stuff works for a 5th gen..... guess it would have helped if i would have asked what year your accord was, but im tired...so yeah whatever). stainless lines =
Old 10-09-2004, 08:31 PM
it's for a 96 lx accord sedan
m735is
09-14-2007 02:27 AM
EJ8_TCAN
07-30-2007 08:54 AM
integra dave
07-31-2004 01:47 PM
dvp95
08-06-2002 05:43 PM
jdmbike
10-04-2001 08:28 AM
Quick Reply: Looking into fixin up my braking system any suggestions on certain brands to use?
