how to reset the ECU?! - Honda-Tech
Old 02-22-2005, 09:12 AM   #1
accord0494's Avatar
Default how to reset the ECU?!
how do you reset the ECU?! if my car even has one?!
1994 honda accord ex candian lx american automatic, 2.2L non v-tec
accord0494 is offline   Reply With Quote
Old 02-22-2005, 09:14 AM   #2
FG Two's Avatar
Default Re: how to reset the ECU?! (accord0494)
use the search feature...
... disconnect the batter or pull the ecu fuse
FG Two is offline   Reply With Quote
Old 02-22-2005, 09:40 AM   #3
accord-lude's Avatar
take out the radio backup fuse in the fuse box under the hood.
accord-lude is offline   Reply With Quote
Old 02-22-2005, 09:42 AM   #4
accord0494's Avatar
Default Re: how to reset the ECU?! (accord-lude)
and leave it out?! or just take it out for a few seconds then put it back in?!
Old 02-22-2005, 12:01 PM   #5
tsdenny's Avatar
Quote:
you leave it out for about 10 minutes or so, then put it back in .. start your car and let it idle for a few mintues.. then your good to go..well atleast thats what i been told.
tsdenny is offline   Reply With Quote
Old 02-22-2005, 12:09 PM   #6
Default Re: how to reset the ECU?! (sleeps2much)
Old 02-22-2005, 12:28 PM   #7
honda_kid42's Avatar
also when restarting, after resetting the ECU don't hit the accelerator just let it idle...
honda_kid42 is offline   Reply With Quote
Old 02-22-2005, 12:44 PM   #8
twkdCD595's Avatar
Default Re: how to reset the ECU?! (honda_kid42)
just as said above...
I just disconnect my neg. battery cable for a few minutes... after reinstallation, start car w/ all the accessories off and let it idle till it reaches the full operating temperature (in most cases the fan will kick on once to let you know... unless in pretty cold weather). Shut it off and your done. Then your ready to go next time you start it.
twkdCD595 is offline   Reply With Quote
Old 02-22-2005, 08:09 PM   #9
accord0494's Avatar
Default Re: how to reset the ECU?! (twkdCD595)
Wicked!! thanks for the help guys!!
so its the radio back up fuse under the hood that i take out for 10 mins then put it back in and start the car with everything off and let it like warm up or whatever then turn it off, and then the next time i start it shes ready to roll?!
cools thanks
how to reset ECU? HONDAVTIS Honda Accord (1990 - 2002) 3 01-23-2007 04:16 AM
ECU reset Pearlude Honda Prelude 4 11-14-2004 07:41 PM
reseting ecu... quick answer!! streetspeed607 Honda Accord (1990 - 2002) 5 05-11-2004 08:18 PM
Resetting ecu Fatty_1775 Tech / Misc 8 08-05-2003 06:37 AM
ECU reset RedHatch Honda Civic / Del Sol (1992 - 2000) 5 01-02-2002 09:34 PM
Tags
1994, 2000, 2004, 2005, 22, 90, 94, accelerator, accord, ecu, honda, insight, modification, reset, resetting, restart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
