Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: How to change serpentine belt
Step by step instructions for do-it-yourself repairs.
How-To: Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1
#501
H-T Order of Merit
Re: How-To: Replace Timing Belt, Timing Balancer Belt and Water Pump on a F22B1
before adjusting tension, you have seated the belt by rotating the engine 5-6 times counter-clockwise correct?
could the spring on the tensioner be worn and not applying enough tension to the belt?
#502
The direction of counter clockwise is while standing on the driver side of the car looking at the pulleys, yes?
#503
H-T Order of Merit
#505
sorry if i missed this on another page but i pushed my front balance shaft seal in too far. do i need to dig it out and put a new one in there or can i just let it go like that?
#506
Maximum tension at that point. If you unhook the spring, it'll drop down and it'll be the least tension IIRC.
#507
H-T Order of Merit
IIRC, while performing step 24, the belt will probably feel the loosest somewhere between the crank and the water pump while feeling the tightest between the cam and crank.
#508
I always do it on my h23 manual conv H22 and the side where the cams & crank has the most tension. This is where it sets itself's proper tension for the timing and balancer belt to where it won't whurr/wine at idle when you do the three teeths counterclockwise and loosen & retighten the adjusting nut if I'm not mistaken.
#509
After I replaced the timing belt and started it up, I noticed the idle at around 1300 rpms. This was a cold engine with the AC on. I didnt let it run more than 15-20 seconds because it was leaking so much oil.
I also had replaced the distributor seal.
Is my idle under these conditions ok? If not, what would the main culprit be? Off a tooth with the belt, or I didn't put the distributor back where it is supposed to be?
#511
H-T Order of Merit
#512
H-T Order of Merit
Should we want there to be maximum tension?
I think this job is amazing for what a simple thing it should be... i mean to turn around and have to put some bs bolt back in to hold it in place...then fuggin go back and loosen the adjustment bolt...
im fuggin praying I do this right....I will never embark on this job again.
Thank god i bought the 03 engine that never needs this to be done to it.
I mean WOW...how can these tensioners be called adjustable and they do not self adjust.?? we're dialing them in!!! and if we do it wrong we botch up the belts... confusing and bs.
This is taking me really long just becuz of all this exact type of nonsense.
I've become religious admist it all.
#514
Yes this is a very confusing part to the job.
Taking it all apart and putting it back together the second time took way way less time.
The new belt is a tiny bit noisy. I'm not sure if I over tightened it, or if its just a new belt.
#515
H-T Order of Merit
#516
I just finished mine today. I ended up having to do it twice in a row because I screwed up the oil seals. >
I could see it overtightening...or even staying too loose....the process does not seem to have any logic behind it...the "tension" ing seems to be almost a crapshot....what if dialing back cam gear 3 teeth does not for w/e reason supply enough tension? What if you didnt exactly open up the so called "adj bolt" exactly 2/3rds?
Way too much room for error.
#517
H-T Order of Merit
and that right there is exactly why I've always chosen to replace that little spring, for the piece of mind that I am getting the right tension.
#518
they are called adjustable because, well,they're adjustable. They aren't self-adjustable and nowhere are they referred as such. If you ever need to adjust the tension... remove the upper side timing cover to gain access to the cam gear, set TDC, loosen the adjusting nut 2/3-1 turn, rotate cam gear 3 teeth counter clockwise, tighten adjusting nut.
I have new springs to put on it.
#519
H-T Order of Merit
#520
is that in the write-up? going to go back and check.
#521
H-T Order of Merit
no no no.... once you do it the first time it's set. if you ever need to adjust the tension, like say the belt is too tight and whining after install, you can adjust without taking everything apart.
#522
Hi Guys…
sorry if this is going to be a seriously NOOB question here but here is what I have done and I can't for the life of me figure it out.
For one I removed the entire engine since I had to get a replacement block.
While the engine was out I had to replace the oil pump (Due to the JDM engine not having the crank sensor), water pump, seals, timing belt and balance belt along with tensioner.
Now on to the questions.
1. I’ve checked and double checked that my TDC lines match on the crank, cam and cover but somehow when I turned on the car and hit it w/ the timing light I’m WAY off. The 3 marks aren’t even close much less is the 1 mark. What can be the problem here?
2. Step 18- I had the belt off and placed the timing sprocket to line up w/ the oil pump manually. Was that the correct way?
3. Step 20- Was I supposed to have tension on the tensioner when installing the belt? Reason I ask is because Step 21 says loosen and retighten the tensioner. Why would this step be required? If you have it loose then put tension on the tensioner?
4. Step 22- The tensioner needs to be loose again correct to install this belt?
5. Step 24- When you say on the write up to loosen the tension bolt and rotate the crank to go 3 teeth on the camshaft then tighten the tensioner. Am I missing something here? Doesn’t both(Crank and camshaft) move forward and piston 1 is descending at this point? Can you please clarify what you mean by this? What is actually happening here?
6. Step 25 – Check you’re still at TDC on the crank, cover and cam. I don’t understand this portion. If I rotated the crank on step 24 isn’t it advanced 3 teeth so how can it be TDC unless I rotate the crank until I go a full turn?
Car is on
7. Why would it show that it’s TDC on the marks everywhere when I rotate the crankshaft but when the car is on it is way off? Unless I’m reading the gun incorrectly.
8. I’m supposed to be looking right at the cover making sure mark lines up right?
9. BIGGER problem when I turn on the car the engine is revving from 2,500 down to 1,100rpm’s like if someone is constantly pumping the gas pedal. What could be causing this?
10. I have a broken sensor that belongs on the back of the intake manifold. Goes right in the center. Could this be an issue for the revving? I highly doubt it since it doesn’t have a vacuum connection.
Thanks for all the help guys.
Car is on
#523
H-T Order of Merit
If this isn't the sensor you are talking about then look for a vacuum leak, maybe a bad gasket or broken hose.
#524
Thanks so much for the response I greatly appreciate it.
Now the question is why the heck when I put the timing light to it…. it’s way off if they all line up when you turn it manually? From your response to my questions it seems I was on the right track.
No coolant lines go to this sensor but I do know it has an electrical connection. I’m trying to find it on hondapartsnow but I don’t see it. It seems the sensor is white w/ a grey connection I wonder if this explain the engine revving like that. it’s just VRrroommm Vrroommmm Vrrooommm LOL I’m like wtf!
