How to replace postive battery cable for 1999 Accord V6 - Honda-Tech
Old 03-24-2008, 12:40 PM   #1
richard9's Avatar
Default How to replace postive battery cable for 1999 Accord V6
Hello,
Does anyone know what is the steps to replace the positve battery cable for a
1999 honda accord V6. Is there any precautionaries that I need to take.
I know about writing down the radio code.
Thanks for any suggestions.
richard9 is offline   Reply With Quote
Old 03-24-2008, 03:05 PM   #2
Default Re: How to replace postive battery cable for 1999 Accord V6 (richard9)
Remove the negative cable first. This will eliminate any possibility of accidently causing a short to ground while working on the postive cable connections.
After you're all done, fire up the engine, and with ALL electrical loads turned off (lights, radio, fan,etc) let it idle without touching the gas pedal until it warms up. This is refered to as the "idle learn" proceedure. I made the mistake of replacing the battery in an auto parts parking lot and jumping right on the freeway to go home afterwards. The engine died the off ramp and for a few stops afterwards until it straightened out.
Perfectionist is offline   Reply With Quote
Old 03-25-2008, 11:55 AM   #3
richard9's Avatar
I believe one end goes to the starter solenoid. The other line end is for the fuse box ?? Are there any precuations or resets, or other items I need to do. I am familier with resetting the radio code.
Old 03-25-2008, 12:35 PM   #4
richard9's Avatar
No power 1999 accord Adam Beem Honda Accord (1990 - 2002) 3 08-08-2016 05:42 AM
1999 Honda Accord LX Battery Size? PeggyB Honda Accord (1990 - 2002) 4 09-22-2015 06:59 PM
1999 Accord LX 4 cyl-auto Starter problem w/terminal B? Eliza68 Honda Accord (1990 - 2002) 2 06-15-2015 07:01 PM
1999 accord v6 auto tranny rross1976 Honda Accord (1990 - 2002) 2 08-17-2009 10:55 PM
how adjust idol? thn116 Honda Accord (1990 - 2002) 22 09-02-2007 07:48 PM
Tags
1999, 2002, 92, accord, battery, cable, cables, ground, honda, positive, removing, replace, replacement, replacing, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
