how to replace ignition lock cylinder - Honda-Tech
Old 12-25-2008, 02:17 PM   #1
jbrune's Avatar
Default how to replace ignition lock cylinder
I have a 91 EX Accord Station Wagon and need to change the ignition lock cylinder. Can anyone provide instructions for this?
Thanks
jbrune is offline   Reply With Quote
Old 12-25-2008, 03:36 PM   #2
hondadude's Avatar
Default Re: how to replace ignition lock cylinder
First remove the steering column shroud; screws are underneath.
Unplug the switch;
Then the "collar" of the lock cylinder has breakaway bolts holding it to the column.
You can use a small chisel on the edge of the breakaway head to get it backing out.
The service manual calls for the bolts to be drilled out.
Then swap over the electrical part of the switch to the new cylinder.
re-assemble everything and go flag your 3/10s of an hour.
hondadude is offline   Reply With Quote
Old 12-25-2008, 03:40 PM   #3
SHAME ON YOU REBECCA!
kidcool1977's Avatar
Quote:
Unplug the switch;
easy as pie. BTW to the OP if you need more info, check HONDAHOOKUP.COM they let you download pdf. manuals for accords. I am certain they have your year
kidcool1977 is offline   Reply With Quote
1995 Accord LX Ignition Cylinder question msmstapes Honda Accord (1990 - 2002) 1 09-02-2016 02:12 AM
2007 Accord v6 key won't turn in ignition wwzjd Honda Accord & Crosstour (2003 - Current) 3 02-11-2015 10:00 PM
civic 2007 ignition lock cylinder acuraTboo Honda Civic (2006 - 2015) 1 12-19-2011 08:04 AM
95 honda prelude ignition cylinder problems! LTreno775 Honda Prelude 1 04-27-2010 11:47 AM
Price for ignition lock switch? Puma General Discussion and Debate 1 12-16-2002 07:55 PM
Tags
1990, 1992, 2003, 91, accord, cylinder, honda, ignition, integra, lock, odyssey, remove, replace, replacing, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
