How to replace clock light in a 2002 Accord - Honda-Tech
Old 09-21-2005, 09:40 PM   #1
jdmspoonitr's Avatar
Default How to replace clock light in a 2002 Accord
Well it happened to two of my accords. I didnt want to bother going to the dealer to find out. I spend most of my time working on Integras so I'm unsure how to replace the bulb and remove the whole center console vent area with the clock. I'm assuming I have to unhook some wire and pop off the buttons just like the integra.
If anyone has a how-to or some tips that would be great because seeing as this happened fairly soon after I got both cars, I would have to assume that it happened to a lot of you guys too. Thanks
jdmspoonitr is offline   Reply With Quote
Old 09-22-2005, 07:12 AM   #2
AFAccord's Avatar
Default Re: How to replace clock light in a 2002 Accord (jdmspoonitr)
It's a relatively simple process, and the 6th gen accords are notorious for this bulb blowing out. I don't have pictures but I will give you a general process for replacing this. You WILL NOT have to remove the climate control panel, just the clock assembly itself.
1. Use a small flat-blade screw-driver to pry the clock/hazard button assembly out of the dash panel. Wrap the screw-driver in a papertowel, tape, or a cloth to avoid scratching the plastic. This usually works best if you pry from one side then the other.
2. There is a vertical connector for the hazard switch, and a horizontal connector for the clock. Disconnect both of these and remove the clock assembly.
3. I believe there is a plastic cover on the back of this assembly. Remove it using a phillips head screw-driver. There you will see the back of the plastic bulb holder.
4. Twist the bulb holder out of the socket and replace the bulb and holder with a new one purchased from a Honda dealership.
5. Installation is the reverse of removal.
I believe this bulb runs $1.47 from the dealer, which is way too much IMO. You could buy an LED bulb conversion from http://www.ledautomotive.com/ if this becomes a continuous problem.
AFAccord is offline   Reply With Quote
Old 03-20-2011, 02:58 PM   #3
Icon2 Re: How to replace clock light in a 2002 Accord
We have a similar problem on a 2002 Accord - took the light out tested on a 9 volt battery - the light works fine!! Is there a connection inside the clock cluster that can be loose?
qwerty1946 is offline   Reply With Quote
Old 03-20-2011, 03:04 PM   #4
nus_dogg's Avatar
God damn, thanks alot for reviving a six years old thread. I'm pretty sure the OP took care of the problem already.
nus_dogg is offline   Reply With Quote
1995 Honda Accord Trying to take out Harmonic Bolt Tonychoi24 Honda Accord (1990 - 2002) 5 11-17-2011 06:29 AM
FYI on fourth generation Accord dash clocks Nicefeet Honda Accord (1990 - 2002) 2 04-08-2011 09:42 PM
EG front brakes won't release WhiteOnRice Honda Civic / Del Sol (1992 - 2000) 2 05-24-2010 01:36 AM
HOW CAN I REPLACE MY CLOCK LIGHT AND ODOMETER LIGHT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! integracura Honda Accord (1990 - 2002) 6 11-28-2005 06:20 PM
Reaplacing clutch.... smoking battery wires 213374U Acura Integra 5 08-30-2005 09:14 AM
Tags
1990, 2000, 2002, 2005, accord, bulb, clock, console, honda, hondaaccord, light, pictures, replace, replaced, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
