89 Accord PA Sensor
Old 04-03-2003, 11:25 AM
smbreheney's Avatar
Default 89 Accord PA Sensor
Before I start tearing things apart on a wild goose chase, what's the precise location of the PA sensor?
Many thanks!
Old 04-03-2003, 11:29 AM
brodsterH22's Avatar
Location: Phoenix, AZ and Humboldt County, CA, USA, USA
Default Re: 89 Accord PA Sensor (smbreheney)
That is the "Piece" of "***" sensor right?
Old 04-03-2003, 11:31 AM
smbreheney's Avatar
Default Re: 89 Accord PA Sensor (brodsterH22)
OK, OK, very funny.
Actually, I *did* laugh out loud.
Old 04-03-2003, 12:13 PM
Tell me what it is and I'll tell you where it is. deal?
Old 04-03-2003, 02:43 PM
smbreheney's Avatar
PA sensor = air pressure sensor, which measures the ambient barometric pressure. Why it isn't called an "AP" sensor is another issue.
Comes up as error code 13 on the ECU.
Some models seem to have it in the passenger compartment, possibly near the ECU. But others seem to bury it under the dash somewhere.
Any help would be greatly appreciated.
Old 03-20-2011, 02:23 PM
MrMax's Avatar
These older posts still show, so here is the location of the PA sensor for 1988 Honda Accord LXi. It's behind the glove box. The connector faces up and it has three leads. red, green/white, yellow. You can get at it easily without moving anything; just have to lay down and look up. The latch on the connector compresses. If you've got the 13 blinks on the fault indicator under the drivers seat, this is most likely your problem. Just unplug it and you should be on your way. You might want to check the wires and replace the sensor someday, but it runs fine without it where I live; no high alt.
2009HondaAccord
02-18-2018 06:41 PM
Tommy Baker
11-18-2012 03:55 PM
951parts
08-09-2012 11:43 AM
dglassmyer
03-12-2012 06:29 PM
wanttorace
11-06-2002 01:09 PM
Quick Reply: 89 Accord PA Sensor
