how to remove a 94 accord bumper?
Re: how to remove a 94 accord bumper?
Very easy but I will try to explain this the best I can.
1. Remove front grille.
2. Go to the the wheel wells and where the bumper connects to the fender you'll see a screw. Remove those screws on both sides. Once removed make sure the little hook part is not attached to the fender. Just pull down a little, don't be afraid, to unhook it from the fender.
3. Next is to remove the bumper lights. You'll need a long screwdriver to get to the screws that are located behind the front bumper.
4. Once you remove the the bumper lights you'll see two screws on both sides. Unbolt them, total of 4 all together.
5. Now where the grille is located and the bumper loose you'll lift the bumper up to unhinge it from the mounts and then pull it away from the car.
Remove the two signal lights on the bumper. On the drivers side signal, to the left of the signal, you will see a little hole in the inner part of the bumper. Inside that hole will be a screw. You will need a long Phillips screw driver. Loosen the screw till the light comes out. You might have to have to use a flat head to pry the light out while unscrewing the screw. The same goes for the passenger side signal except the hole is on the right.
After removing the signals, you will see inside the bumper two bolts vertically that bolt up to the bumper mount. There are two bolts per side. Remove them.
Lift the bumper up and it should come out. Usually you have to mess with it for it to come out. It helps to push it up and down untill it comes out.
SupraRXZ
14
11-29-2006 10:30 AM
