How much should i expect to pay?
Old 02-22-2005, 03:44 AM
MS99k's Avatar
Default How much should i expect to pay?
Hey guys,
I need to replace my crank seal and im going to have them do the timing belt at the same time, how much could i expect to spend on this?
Thanks
Old 02-22-2005, 09:22 AM
Luisito825's Avatar
Default Re: How much should i expect to pay? (MS99k)
250ish
Old 02-22-2005, 10:29 AM
SuperSlow's Avatar
Default Re: How much should i expect to pay? (ogbusboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogbusboy &raquo;</TD></TR><TR><TD CLASS="quote">250ish</TD></TR></TABLE>
That is a good price. IF you go to the stealership you will spend a grand for it all.
Old 02-22-2005, 11:15 AM
Luisito825's Avatar
Default Re: How much should i expect to pay? (SuperSlow)
i was talking about labor only. dealer's charge that much for labor only??!!
Old 02-22-2005, 11:44 AM
SuperSlow's Avatar
I mean for parts/labor on both.
Old 02-23-2005, 11:24 AM
MS99k's Avatar
aight, cool thanks guys cuz im leaking a tad bit of oil and the mechanic that replace the oilpan told me it was a crankseal. but i was checking things out, is it possible to be leaking from the valve cover gasket, im waiting for the motor to cool atm to go change it. there is about a half inch of oil sitting in all the plug wells, i just got the car saturday and im trying to get everything straightened out.
Mike
Old 02-23-2005, 12:40 PM
SpeedFreak77's Avatar
While you are at it change the small seals around the plug holes also since you will have the valve cover off. They just pull right out easy and cheap to replace since you have the cover off.
Old 02-23-2005, 01:29 PM
MS99k's Avatar
Default Re: How much should i expect to pay? (SpeedFreak77)
i replaced those aswell because thats part of my problem theres so much oil getting out into the wells that is fouling out my spark. the plugs are dripping with oil so i put new ones in too.
Hondas_Only
05-11-2007 08:46 PM
Extreez
01-21-2007 05:57 PM
chrimy90cx
15
12-23-2006 08:48 AM
XenoPhobe
01-27-2004 01:20 PM
hYpE-R-29
05-13-2003 06:16 PM
Quick Reply: How much should i expect to pay?
