still slipping
still slipping
When I got my accord it need a new clutch and rifht half shaft. I bought all the parts and had them installed by a local tuning shop. I broke her in like youre suppose to after ward. Her we are 1300 miles later and it feels like the new clutch is still slipping when passed 3k rpm. It starts screaming and bouncing, loses power until I shift gears. Any suggestions
Re: still slipping
Was the clutch replaced because it was slippin before? If it was, and it was slipping A LOT; then some attention should have been directed at the flywheel. Under prolonged slipping conditions, excessive heat builds up - and the flywheel developes hot spots which actually can deform the friction surface. This will NOT cause slipping but it will cause chattering and uneven clutch engagement.
Hope this helps
P
Re: still slipping
i had the same problem. changed my clutch. do the rpms go up and it feels like its trying to move? do the clutch test to see if its really slipping.. this may sound wierd but take the cat off and see if its clogged. thats what happend to me and mines runnin great now.
