heater fan? trouble plz help
Old 05-29-2005, 01:37 PM
davendonna's Avatar
Default heater fan? trouble plz help
well my fan went out 2 weeks ago and since its almost summer im in no hurry to fix it but i noticed this, could this be my prob ? it looks a little toastie, i'll look thru the wiring diagrams but if ne1 knows b4 i find plz let me know sumtin
ps wat is this wire?
Modified by davendonna at 11:31 AM 5/31/2005
Modified by davendonna at 11:33 AM 5/31/2005
Modified by davendonna at 6:50 AM 6/1/2005
Old 05-29-2005, 05:01 PM
deserthonda's Avatar
so no air from vents,,,what year is it ???
Old 05-29-2005, 09:52 PM
davendonna's Avatar
Default Re: (deserthonda)
yeah i got the sunroof for defrost but, it dont as well as the fan did,ha ha,
its a 95 ex coupe
Old 05-29-2005, 09:57 PM
davendonna's Avatar
oh yeah the ac wont come on no more either i dont know if its just the switch or the blower unit. and im askin a lot of ?'s before i do anything chilton says i have to take out the dash and airbags to get at at the blower unit which i can handle but not looking forward to
Old 05-29-2005, 10:02 PM
you still did not answer my question ARE YOU GETTING ANY AIR FROM THE VENTS??and no you don't have to remove dash and air bags to remove blower motor if that is your problem ,and if you are not getting any air flow from vents your a/c will not blow either
Old 05-29-2005, 10:21 PM
davendonna's Avatar
NO I AM NOT!!i figured you get that from the joke about the sunroof "no defrost"!
ima dummie
ps thats why i have the noob avatar i guess
Old 05-29-2005, 10:29 PM
davendonna's Avatar
chiton says "take dashboard out of vehicle" thats if i have to remove the unit,i hope it's the switch on the control panel or the wiring in the photo i'll try to follow the wire at launch 2day i'll tell u about what i find around 10:00 am gota go to work
Old 05-31-2005, 10:29 AM
davendonna's Avatar
now i know wat's going on you were tellin me about the right part i was thinkin heater-core but i wanted to be thinkin blower motor.
SRY BOUT THE DOUBLE POST GUYS GIMME TIME AND I'LL STOP ****** UP
PS I STILL WANT TO KNOW WAT THAT WIRE IS FOR SO PLZ TELL ME
Modified by davendonna at 11:44 AM 5/31/2005
Modified by davendonna at 11:45 AM 5/31/2005
Old 05-31-2005, 11:03 AM
here is what u do, first off chk fuses underdash fuse box fuse # 8 7.5 amps,, underhood fuse box # 17 30 amps...if either is no good replace and retry.. if fuses are ok rt side underdash at blower motor there is a 2 wires plug chk for power at yellow/black and ground on blue/red,,, if you got both motor is no good,, if no power at yellow/black could have a bad relay or wiring problems if no ground at blue/red could have a bad blower switch or wiring ,,hope is just a fuse..
Old 05-31-2005, 02:51 PM
davendonna's Avatar
thank u so much im sry i thought bad thoughts of you
ps u rock
raysdb7
02-24-2013 01:41 PM
mymeatb18"
10
01-03-2005 07:50 PM
Keno20
11-24-2004 08:34 PM
Quick Reply: heater fan? trouble plz help
