how to install harmonic balancer bolt - Honda-Tech
Closed Thread
Old 04-08-2011, 09:58 AM   #1
Default how to install harmonic balancer bolt
98 accord 2.3l v-tec,i got it out but when i go to put it on engine rotates,do i use lok tite?
kamilog is offline
Old 04-08-2011, 10:34 AM   #2
GhostAccord's Avatar
Default Re: how to install harmonic balancer bolt
You need to keep the crank from rotating in order to get the proper torque specs. You will need to use a Honda crank pulley tool to keep the crank from rotating. Or find another way to keep the crank from rotating. I have a crank tool so I'm not sure of the back yard mechanics way of doing this. Someone else will have to chime in.
Powerbuilt 648796 Honda Crankcase Pulley Removal Tool $21.46
GhostAccord is offline
Old 04-08-2011, 04:51 PM   #3
GDD Member
slomofo's Avatar
Most people use an air gun to get it as tight as they can. I torque them on, but outside of the dealer and a few people like me, I've never seen anyone else torque them to proper specs because most people don't have a torque wrench that'll go up to 181 pounds which is the proper spec.
slomofo is offline
Old 04-08-2011, 10:34 PM   #4
MM Gruppe B
MAD_MIKE's Avatar
Quote:
That's why you use a breaker bar, a little math, and stand on it.
MAD_MIKE is offline
Old 04-09-2011, 03:04 PM   #5
Accordin2me's Avatar
If you have an old serpentine belt lyin around you can have a buddy hold it tight around the crank while you torque it.
Accordin2me is offline
Old 05-25-2013, 12:28 PM   #6
put in 5th gear and hold the brake
noface is offline
Old 09-08-2014, 05:16 PM   #7
Hey guys I am trying to find the specs for the torque needed on a 92 acura integra harmonic balancer. If anyone has those numbers, please let me know. I believe its like 130.. but I can't remember, it's been some time. Also, any tips on getting the tensioner bolt loose on the alternator? Can't seem to get an angle to get the socket on the bolt.
stringseagle is offline
Old 09-08-2014, 05:48 PM   #8
Quote:
^this
///Mo-betta is offline
Old 09-08-2014, 06:43 PM   #9
No.
Old 09-08-2014, 08:46 PM   #10
Quote:
It says the proper torque earlier in this thread and autozone and oreilly both rent out the crank holder tool now.
holmesnmanny is offline
Old 09-09-2014, 10:12 AM   #11
94 accord typeR's Avatar
http://honda-tech.com/forumdisplay.php?f=6
94 accord typeR is offline
Old 09-09-2014, 10:13 AM   #12
no this thread is about a 98 accord 2.3l.. I'm asking about a 92 integra 1.8l. So no, it's not earlier in this thread. All I need is the torque number on it, I've done this before but I just don't remember how much torque it calls for.
Old 09-09-2014, 02:50 PM   #13
" Acura Integra - Honda-Tech " not sure what I am supposed to find here...
Closed Thread
If I make a troll thread, will I get SIRIUS replies? FrreeeBird General Discussion and Debate 60 11-21-2011 07:49 AM
My wheel horror... Newborn_ Honda Civic (2001 - 2005) 14 02-07-2007 10:17 AM
need help with b18 block matt c Acura Integra 8 11-09-2006 04:00 PM
??????? vanillabeans For Sale 6 02-28-2004 07:56 PM
Turbo questions: i Honda Civic / Del Sol (1992 - 2000) 7 10-20-2003 12:30 AM
Tags
02, 1992, 2002, 23l, 91, 93, accord, balancer, bolt, crv, harmonic, honda, install, installing, odessy, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
