TECH: 5th Gen OBDII ECM/PCM Terminal Arrangement
1 Post
TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement
I know some people wanted this, so I'm posting it up.
This is straight out of the factory service manual.
***Some wires may be the same color on the same connector, so also go by pin position. Pin position goes from left to right, top to bottom; looking at the connector with the latch side up.***
***Column 1 is wire color--->column 2 is terminal name***
<U> Connector A (32P) </U>
YEL--->INJ4 (#4 FUEL INJECTOR)
BLU--->INJ3 (#3 FUEL INJECTOR)
RED--->INJ2 (#2 FUEL INJECTOR)
BRN--->INJ1 (#1 FUEL INJECTOR)
ORN/BLU--->SO2SHTC (secondary heated O2 sensor heater control)
ORN/BLK--->PO2SHTC (primary heated O2 sensor heater control)
RED--->ESOL (egr control solenoid valve)
GRN/YEL--->VTS (VTEC solenoid valve) *3
BRN/BLK--->LG1 (logic ground)
BLK--->PG1 (power ground)
YEL/BLK--->IGP1 (power source)
BLK/BLU--->IACV (idle air control valve)
GRN/WHT--->MCS (engine mount control solenoid valve) *4
RED/YEL--->PCS (evap purge control solenoid valve)
GRN/BLK--->FLR (fuel pump relay)
RED/BLU--->ACC (air conditioning clutch relay)
LT. GRN/RED--->MIL (malfunction indicator lamp) (a.k.a., CEL)
WHT/GRN--->ALTC (alternator control)
YEL/GRN--->ICM (ignition control module)
BRN/BLK--->LG2 (logic ground)
BLK--->PG2 (power ground)
YEL LT BLK--->IGP2 (power soure)
ORN/GRN--->IAR SOL (intake air resonator control solenoid valve)
GRN--->FANC (radiator fan control)
GRN LT WHT--->2WBS (evap bypass solenoid valve) *1
ORN/GRN--->VSV (evap control canister vent shut valve) *1
<U> Connecotr B (25P) FOR AUTOMATICS ONLY </U>
BLU/YEL--->SHA (shift control solenoid valve A)
GRN/BLK--->LC B (lock-up control solenoid valve B)
YEL--->LC A (lock-up control solenoid valve A)
GRN/BLU--->ATPD3 (a/t gear position switch)
GRN/WHT--->SHB (shift control solenoid valve B)
WHT/GRN--->ILU (interlock control unit)
BLU/RED--->D4 IND (d4 indicator light)
WHT/BLU--->NMSG (mainshaft speed sensor ground)
ORN/BLU--->NM (mainshaft speed sensor)
GRN/RED--->ATPR (a/t gear position switch)
GRN/YEL--->ATP2 (a/t gear position switch)
LT. GRN/WHT--->ATP1 (a/t gear position switch)
BLU/YEL--->NCSG (countershaft speed sensor ground)
BLU/GRN--->NC (countershaft speed sensor)
LT. GRN/BLK--->ATPD4 (a/t gear position switch)
LT. GRN--->ATPNP (a/t gear position switch)
<U> Connector C (31P) </U>
BLU--->CKPP (crank position sensor side)
GRN--->TDCP (top dead center sensor side)
YEL--->CYPP (cylinder position sensor side)
RED/WHT--->ACS (a/c switch signal)
BLU/RED or BLK/GRN on m/t--->STS (starter switch signal) *1
RED--->SCS (service check signal)
LT. GRN---K-LINE (sends and recieves scan tool signal)
WHT/YEL--->VBU (voltage back up)
WHT--->CKPM (crank position sensor m side)
RED--->TDCM (top dead center sensor m side)
BLK--->CYPM (cylinder position sensor m side)
GRN--->PSPSW (power steering pressure switch)
WHT/RED--->ALTF (alternator fr signal)
ORN--->VSS (vehicle speed sensor)
BRN--->PFSW (evap purge flow switch) *2
<U> Connector D (16P) </U>
RED/BLK--->TPS (throttle position sensor)
RED/WHT--->ECT (engine coolant temperature sensor)
WHT/YEL--->MAP (manifold absolute pressure sensor)
YEL/WHT--->VCC1 (sensor voltage)
GRN/WHT--->BKSW (brake switch)
WHT/RED--->PHO2S (primary heated O2 sensor 1)
RED/YEL--->IAT (intake air temperature sensor)
WHT/BLK--->EGRL (exhaust gas recirculation valve lift sensor)
YEL/BLU--->VCC2 (sensor voltage)
GRN/BLU--->SG2 (sensor ground)
GRN/WHT--->SG1 (sensor ground)
RED/WHT--->SHO2 SG (secondary heated O2 sensor, sensor 2 ground)
WHT/RED--->SHO2S (secondary heated O2 sensor, sensor 2)
GRN/RED--->PTANK (fuel tank pressure sensor) *1
GRN/RED--->EL (electronic load detector)
*1: Sedan KA (EX), KL (DX, LX w/ABS, EX), KC (EXR), Coupe models
*2: Sedan KA (DX, LX), KL (LX w/o ABS), KC (LX,EX), Wagon models
*3: F22B1 engine
*4: A/T
If there are any questions IM me.
[Modified by carolinaACCORD, 10:46 PM 2/11/2003]
*3: F22B1 engine
*4: A/T
Re: TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement (carolinaACCORD)
Great info! Does this apply to OBD I (94-95) Accords as well? Where did you find this info??
Ok I have the helms for my car (94) and I couldn't find this info anywhere in it. There is no index. What section/heading do you look in. BTW, I also have the helms electrical supplement and I haven't seen it in there either.
1 Post
Re: TECH: 5th Gen Accord OBDII ECM/PCM Terminal Arrangement (Stew Pidasso)
when you find it, please look over it and post any differences there may be if you dont mind.
Powered By Garrett
03-30-2008 08:44 AM
slorex
08-31-2005 09:42 AM
