How easy are 99 rotors to change?
Old 05-06-2005, 12:20 PM
Klutch's Avatar
Default How easy are 99 rotors to change?
I think my front rotors are warped and since they are so cheap I might just change them. How hard are they to change on a 99 Accord?
Old 05-06-2005, 12:43 PM
stinker504's Avatar
The only problem you might run into are the two holding screws. Sometimes they get stuck on pretty good. A lot of people just drill the heads off and use the rim to hold the rotor on. Keep in mind many cars do that. My new rotors didn't line up with the holes so I left them out. No problems and almost 2 years ago.
Old 05-06-2005, 01:06 PM
notoriousB's Avatar
Default Re: (stinker504)
stinker's right, easy cheesy, the screws can be a bitch, I personally drilled them out and left them out, you don't need them.
Old 05-06-2005, 01:16 PM
fw190bvi's Avatar
Default Re: (notoriousB)
6th gen's arent hub over rotor, correct?
Old 05-06-2005, 02:22 PM
notoriousB's Avatar
Default Re: (fw190bvi)
they are not, you are correct. rotor over hub.
Old 05-06-2005, 02:38 PM
deserthonda's Avatar
no don't drill the screws too much work get an impact screwdriver and phillip bit, hit the screws with tool and hammer makle sure you are going counterclock and they will come off real easy ..if you cannot get hold of impact screwdriver get a small sharp punch hit screw on flat surface to make a little hole. hit the screw counterclock on the hole and it will come of they are not that tight
Old 05-06-2005, 03:19 PM
notoriousB's Avatar
Default Re: (deserthonda)
impact driver didn't budge the screws in my rotors. new england's a bitch on cars. and yes I used it the right way.
Old 05-06-2005, 06:30 PM
npcanibus3's Avatar
i agree with the impact, you can be there all day pounding away and it still wont budge. Even if you crack it open after an hour, the heads on the screws are probaly eaten out.
eric416
12-02-2009 02:55 PM
Aqualungs
09-15-2009 04:53 PM
Wendys or Bust
10-24-2006 07:11 PM
rus
11
06-05-2006 12:01 PM
Drag-On23
10-28-2003 08:29 AM
Quick Reply: How easy are 99 rotors to change?
