How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTEC? - Honda-Tech
Old 02-03-2007, 09:26 PM   #1
LABachlr's Avatar
Default How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH?
I want to replace the fuel filter on my Accord EX 2.2 VTECH. Anyone have a link to a tutorial with pictures, or anyone want to post one here?
TIA
LABachlr is offline   Reply With Quote
Old 02-04-2007, 09:26 AM   #2
hondadude's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (LABachlr)
hondadude is offline   Reply With Quote
Old 02-04-2007, 09:45 AM   #3
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (hondadude)
dont try it unless you are good with car, i spent like three hours getting the bit-h bolt off the top with a vise and a wrench
iam7head is offline   Reply With Quote
Old 02-04-2007, 09:56 AM   #4
R.I.P.
hapexamendios 2.0's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (iam7head)
Quote:
ditto, pain in the ***, be careful not to bend the fuel lines
hapexamendios 2.0 is offline   Reply With Quote
Old 02-04-2007, 10:20 AM   #5
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (hapexamendios 1)
Quote:
fat hands for the lose
yeah, don't drop the washer thing too, if you forget the put in the brass washer or forgot to take out the worn washer it will spray you with gasoline upon fire up
Old 02-04-2007, 12:39 PM   #6
LABachlr's Avatar
Thanks for the link and advice. I think I'll pass on this one and have the mechanic do it. BTW, at what mileage should it be replaced? Have about 84,000 on it right now.
Old 02-04-2007, 07:37 PM   #7
hondadude's Avatar
It is not in the service schedule anymore; But by 90k it should have some junk in it. The official change time, is when you lose fuel pressure from blockage.
Old 02-04-2007, 07:44 PM   #8
iam7head's Avatar
we changed our around 140k and there's not much "stuff" in it, the same can't be said for my acura legend filter, it was caked with yellow dust
Old 02-04-2007, 07:54 PM   #9
hondadude's Avatar
Well almost all gas pumps have filter systems nowadays, So there is a lot less chance of getting junk in the gas tank.
Old 02-04-2007, 08:03 PM   #10
SuShiBoiiii's Avatar
when do you know its time to change or should i just change when i get to like 150k?
SuShiBoiiii is offline   Reply With Quote
Old 02-04-2007, 11:50 PM   #11
jli18's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (SuShiBoiiii)
whats the use of changing the fuel filter? i never changed mine, and my car has 140k miles on it right now
jli18 is offline   Reply With Quote
Old 02-05-2007, 12:00 AM   #12
iam7head's Avatar
Quote:
around 100k, but your 6th gen doesn't have a real filter.
Old 02-05-2007, 12:03 AM   #13
iam7head's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (jli18)
Quote:
filter: a device(fuel filter) that remove something(junk from the pump gas) from whatever pass thru it
pretty much the same idea for oil filter, air filter, a/c filter, light filter, atf filter, etc
change it if you haven't already, the legend/civic/teg filter is right by the firewall, which took less than 10 seond to remove
the accord 5th gen filter is between the steeringrack/crossmember and the loop of brake hoses, a royal paining **** to work on. the same go for DSM eslipse, it's mounted by the firewall under abunch of crap. Gas just leaks to your arm pit when you work on it
Old 02-06-2007, 07:41 AM   #14
LABachlr's Avatar
The reason why I want to change the filter is to improve the gas mileage. I'm getting around 17mpg around town, and should be getting around 23 according to my car's stats.
I've already done the following:
replaced and gapped the spark plugs
poured fuel system cleaner into the gas tank
replaced the air filter
replaced the spark plug wires
replaced two tires (other two are almost new) and gave them all 36psi
I still plan on replacing the distributor cap and rotor, and of course the fuel filter.
Is there anything else I can do to improve the gas mileage?
Modified by LABachlr at 7:56 AM 2/6/2007
Old 02-06-2007, 07:51 AM   #15
H-T Order of Merit
TouringAccord's Avatar
Maybe try cleaning your EGR ports.
Check the FAQ for a How-To on cleaning the EGR ports, it's located in the Engine section.
TouringAccord is offline   Reply With Quote
Old 02-06-2007, 07:58 AM   #16
LABachlr's Avatar
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (TouringAccord)
OK. Thanks. The FAQ section of what? Don't see any FAQ section on this site.
Old 02-06-2007, 08:07 AM   #17
H-T Order of Merit
are you joking?
It's stickied at the top of the Accord forum. Called Accord FAQ
Old 02-06-2007, 09:05 AM   #18
LABachlr's Avatar
Ah. A sticky. I was looking for a complete FAQ forum. My bad. Thanks.
Modified by LABachlr at 9:33 AM 2/6/2007
Old 02-06-2007, 09:21 AM   #19
H-T Order of Merit
yep, no problem.
Remember to look in there and search when your looking for something, chances are you'll find it between the two. If you find a good how-to or a good thread that you feel should belong in there, send a PM to a mod (myself or -RedneckDave-) and we can read it and add it if needed.
Old 02-06-2007, 09:33 AM   #20
LABachlr's Avatar
Cool. Will do.
Old 02-06-2007, 10:15 AM   #21
fleetmack's Avatar
what can one expect to pay a mechanic to replace a fuel filter?
I still get decent gas mileage and am on my original at 216K .... thinking I'm overdue, but this sounds like a pain in the *** that i'll gladly pay someone to do
fleetmack is offline   Reply With Quote
Old 02-06-2007, 11:10 AM   #22
H-T Order of Merit
Default Re: How do you replace the fuel filter on a 1995 Honda Accord EX 4dr 2.2 VTECH? (fleetmack)
It's not as hard as it seems with the proper tools. Crowfeet make the job much easier.
Old 02-06-2007, 12:41 PM   #23
fleetmack's Avatar
i'm very ignorant, what are crowfeet?
Old 02-06-2007, 04:41 PM   #24
H-T Order of Merit
You can see them in the link at the beginning and how to use them in this situation.
Old 02-06-2007, 05:51 PM   #25
iam7head's Avatar
Quote:
overrated
i was doing it with 99cents vise grip in one hand and wrench in the other, make sure you tape the tools and use a rubber band to wrap around your hand, you will drop it couple of time on the removal
fuel filter for 1999 accord 4cyl 1999accord Honda Accord (1990 - 2002) 21 12-21-2016 11:38 AM
Do anyone know where the fuel filter is on a 98 accord 2.3? KDoGx504 Honda Accord (1990 - 2002) 16 09-07-2016 01:29 PM
New Parts on an 184kmile 1995 Accord. AdammBone Honda Accord (1990 - 2002) 3 03-06-2015 06:51 AM
95 Accord Ex Removal of Fuel Filter sca2face Honda Accord (1990 - 2002) 5 10-12-2006 05:38 PM
fuel filter replacement sshaikh01 Honda Civic / Del Sol (1992 - 2000) 1 02-11-2002 01:12 PM
Tags
1995, 22, 95, accord, bolt, change, ex, filter, fuel, fule, honda, location, pump, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
