How do you force pass. window up '93 accord - Honda-Tech
Old 10-22-2011, 02:43 PM   #1
Default How do you force pass. window up '93 accord
My passenger window wont go all the way up, the motor is bad. its down about 1/4-1/2 an inch and rain is getting in. whats the easiest way to force that window up, or what to seal with. thanks
lastronaut is offline   Reply With Quote
Old 10-22-2011, 03:00 PM   #2
rayo53's Avatar
Default Re: How do you force pass. window up '93 accord
Just put both your palms on the window and have someone push the "up" switch on the door and push it up. Or just push it up, push the button and work your way up. Most Accords do that.
rayo53 is offline   Reply With Quote
Old 10-22-2011, 03:12 PM   #3
I just tried that, the window button doesnt do anything when pushed. im putting all my strength into it and trying to get the window up and it wont. im trying to avoid turning this into a huge project. thanks for your input
Old 10-22-2011, 03:28 PM   #4
Smallboxx's Avatar
take the door panel off and remove window regulator motor (it has three bolts holding it into the door panel) and then unbolt the regulator (it is the bracket assembly that the motor drives) from the window and ... there u go. slide the window up and figure out how to make it stay up (any way u can)
Smallboxx is offline   Reply With Quote
Old 10-24-2011, 04:06 AM   #5
hondamark35's Avatar
Quote:
I've wedged PVC pipe, pieces of wood... whatever i had laying around that was the right hieght inside the door to hold the window shut for a few days while waiting for parts to ship. Used some loops of duct tape or zip ties to secure it and keep it from slipping out while going down the road.
hondamark35 is offline   Reply With Quote
[1997 Acura CL] Power Window Cable tight TechyJR Tech / Misc 4 09-07-2016 06:08 PM
Help with broken Power window: forced roll up gqskrub Honda Civic / Del Sol (1992 - 2000) 4 04-19-2016 07:43 PM
WINDOW WONT GO UP. matchewspoo Other Make Vehicles 7 03-04-2010 03:52 PM
slow windows r1ch Honda Accord (1990 - 2002) 6 12-04-2006 08:46 PM
1990 Honda Accord window problem..... windcalmer Honda Accord (1990 - 2002) 5 08-07-2004 04:22 PM
Tags
1997, 2001, 93, 97, accord, acura, back, force, honda, make, roll, stay, tl, window, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
