How do I remove the door panels? - Honda-Tech
Old 06-27-2008, 11:43 AM   #1
EvenStar's Avatar
Default How do I remove the door panels?
95 Honda Accord LX 2dr
Story: I was going back to my car, got in, started up the engine and rolled down my windows. I noticed that it wont roll down and it was making some sort of ticking noise. I pressed down again and the window rolled ALL THE WAY DOWN. Now I cant roll it back up. When I press the roll down button, this black wire comes out. Wtf is going on? How do I remove the door panels so that I can see what the heck is going on?
This is for the driver side btw.
EvenStar is offline   Reply With Quote
Old 06-27-2008, 01:00 PM   #2
n_csmith's Avatar
Default Re: How do I remove the door panels? (EvenStar)
if its anything like my car which it may or may not be the actual door handle slides back and comes out after you take the screw out then the door panel will pop off after you take out the screw under the cap in the armrest inside the hand hold. if that all makes sense haha. there may be other screws too just look for caps.
n_csmith is offline   Reply With Quote
Old 06-27-2008, 01:40 PM   #3
* B A N N E D *
1 screw is under a plastic cover in the handle
1 screw is under the mirror control on that vinyl handle
1 screw is under a cover at the base of that handle where it meets the door
1 plastic screw is at the top below the mirror cover
pop out mirror cover (couple clips, pull out and up)
take off speaker grille
wedge fingers in between panel and metal and start tugging outwards, there's ~15 clips around the door
TheMuffnMan is offline   Reply With Quote
Old 06-27-2008, 01:57 PM   #4
n_csmith's Avatar
Default Re: (TheMuffnMan)
definetly different then my car...haha mine is much easier three screws slide the door handle back and pull on the panel and it comes off
Old 06-27-2008, 08:45 PM   #5
EvenStar's Avatar
great thanks guys! apparantely the regulator was messed up so i had to replace it.. costed me 1/4 of an arm
1996 honda accord - Window rolls up crooked - FIXED Dev1996 Honda Accord (1990 - 2002) 1 10-20-2015 07:28 AM
92 honda accord lx passenger - Passenger window won't roll down after.. captainhecubus Honda Accord (1990 - 2002) 4 08-20-2012 07:50 PM
Need help with driver side window because it's not working! Buktheng Honda Accord (1990 - 2002) 0 12-06-2007 02:04 PM
96 Accord LX Driver Side Power Window priestfan Honda Accord (1990 - 2002) 3 11-26-2006 03:49 AM
Window Wont Roll Up hometheaterman Honda Accord (1990 - 2002) 15 11-15-2005 11:03 PM
Tags
1991, 95, accord, door, engine, honda, lxhow, odyssey, panel, panels, plastic, prelude, remove, removing, screws, speaker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
