Bearings
Old 10-17-2002, 02:10 PM
Banned
CardDealer's Avatar
Default Bearings
Modified by CardDealer at 4:13 PM 11/17/2006
Old 10-17-2002, 04:04 PM
GZERO's Avatar
Default Re: Bearings (schlit)
BUMP for you, i want to know too
Old 10-17-2002, 05:05 PM
niedejb's Avatar
Default Re: Bearings (GZERO)
Well. Cams dont have bearings.
Crank and rod bearings are about as hard as you can get steel. Their hardness against the crank (also hard as a damn rock...probably carburized) keeps them from wearing each other. Of course they generate heat and require removal of the heat (oil), but they also use the oil as a fluid "bearing" between them.
Think of the gears in your tranny. Theyre metal to metal as well. They use the oil to cool and prevent scoring.
The best I can describe it is theres a thin layer of oil between them that cannot be compressed (principle behind hydraulics).
Old 10-17-2002, 08:03 PM
GZERO's Avatar
Default Re: Bearings (niedejb)
ok, but why not use roller bearings like turbos for example? i think bearings are one of the best discoveries of the century, but i still can figure out how they really work? i understaned what you said, but still, if is that hard why doesn't the rod or crank worn out at a faster rate?
Old 10-18-2002, 05:01 AM
Stew Pidasso's Avatar
I believe the molecules of oil roll around like bearings. This is why it is slippery, because it's like a bunch of ball bearings. The very hard surfaces of the crank and rod ride on the oil, not on each other...
Old 10-18-2002, 11:24 AM
Banned
CardDealer's Avatar
Default Re: Bearings (Stew Pidasso)
Old 10-18-2002, 11:33 AM
SOHCArchangel's Avatar
he explained the layer of oil between parts, plus man smokey eunich once built a roller bearing motor , do you have the amount of funds necessary to amke one, it is simply impractical for conventional uses, just get the bearing surfaces micropolished
Old 10-18-2002, 11:57 AM
Default Re: Bearings (SOHCArchangel)
Plus imgine the stress the ball/rollers would have to withstand. If one ball or roller would get scored or dented the whole assembly would fail.
Old 10-18-2002, 01:08 PM
niedejb's Avatar
The journals in the top of the head hold the cam. Just aluminum grooves that the cam rides in.
The crank and rod bearings have holes and recesses that line up with holes in the crank.
Old 10-18-2002, 01:10 PM
i think that the stress would be easily dissipated to rotational motion as the whole concept of the idea, lubrication will still be needed as always...lemme do some research on this issue.....
Old 10-18-2002, 01:20 PM
GimpyAccord's Avatar
someone in here knows who Smokey Yunick .. i suddenly have way more respect for this forum. ever read "Power Secrets" ?
Old 10-18-2002, 05:07 PM
jweller's Avatar
Default Re: Bearings (GimpyAccord)
read some of it. my friend took it back before I could finish.
pjr710
08-20-2008 01:03 PM
B18CivicHatch
09-28-2007 08:38 PM
94-integra-ls
05-08-2006 03:37 PM
ulemu
12
01-03-2006 12:37 PM
dustin
10-23-2002 12:06 PM
Quick Reply: Bearings
