How to determine which O2 sensor is bad - Honda-Tech
Old 10-25-2009, 03:52 PM   #1
New User
atuvy's Avatar
Default How to determine which O2 sensor is bad
The check engine light is on, I checked with a scanner and the code is listed below, it does not tell me which one of the two sensors is bad. How can I determine that, I would appreciate any help
Code: P1166 HO2S11 Heater Circuit Fault.
Engine Info:
2000 Honda Accord EX 4 Cyl
F23A4
Edit/Delete Message
atuvy is offline   Reply With Quote
Old 10-25-2009, 04:13 PM   #2
Moderator
tech8's Avatar
Default Re: How to determine which O2 sensor is bad
P1166 is the air/fuel ratio sensor, which is the primary sensor.
Here is also a link with a pdf for a few test for code P1166.
http://www.driveaccord.net/forums/sh...d.php?p=229281
tech8 is offline   Reply With Quote
Old 10-25-2009, 04:52 PM   #3
I concur. It is the primary O2 sensor. The clue is in the code, HO2S1. If it were a problem in the secondary sensor, you would have read HO2S2.
92civlude is offline   Reply With Quote
Old 10-25-2009, 04:59 PM   #4
New User
atuvy's Avatar
Thank you guys for the quick response. My OBD reader says that it has a problem with the heater but when I turn the ignition on the sensor heats up very quick
Old 10-25-2009, 05:06 PM   #5
P_Adams's Avatar
Quote:
It may heat, but it is not remaining heated. More than likely the internal resistance is out of range, thus the warning lamp.
P
P_Adams is offline   Reply With Quote
Old 07-20-2012, 07:45 AM   #6
PMT
Can someone tell me where the air/fuel ratio sensor is on the 2008 civic si and why my dealer wants $583.00 to replace it?
PMT is offline   Reply With Quote
Old 07-21-2012, 01:51 AM   #7
361 accord's Avatar
Quote:
idk and cuz they suck
here you go http://www.8thcivic.com/forums/do-yo...placement.html
thats everything you need, literally part numbers a place to buy, also try BKhondaparts.com, and autopartswarehouse or even googling the denso part number
all you need is one normal looking wrench, don't bother with those retarded O2 sockets, theres no room to use them on there anyways
361 accord is offline   Reply With Quote
Old 07-21-2012, 04:50 AM   #8
I just cut the wires, and use a regular socket(Youre going to replace it anyway). Install use a regular wrench, or a flare socket/wrench
tim73 is offline   Reply With Quote
99 Accord code P0327 KRCXIV Honda Accord (1990 - 2002) 1 06-16-2016 01:33 AM
2006 Civic Issues - Rocker Arm to O2 Senor - Advice needed skyline315 Tech / Misc 15 12-10-2009 06:20 PM
1998 Civic: Voltage Signal from Transmission Sensor Out of Range Rose of Cairo Honda Civic / Del Sol (1992 - 2000) 2 11-18-2008 08:23 PM
P1164 Error Code PCM/O2 Sensor problem inzecure1 Honda Accord (1990 - 2002) 4 03-18-2004 11:43 PM
Check Engine Light -- steps to determine code? Todd00 Acura Integra Type-R 4 05-24-2002 08:04 PM
Tags
02, 2002, af, civic, code, fault, faulty, heated, honda, o2, oxygen, p1166, primary, ratio, sensor, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
