h22 swap
Old 09-22-2005, 03:38 PM
force-fed's Avatar
Default h22 swap
Did not search I need to know asap what ecu to get for 93 lx accord with h22a swap, getting everything but ecu. I heard p 28 or p13. I've never done a swap so just wondering what ecu would be best ?
Old 09-22-2005, 04:30 PM
Officer's Avatar
Default Re: h22 swap (f22hafler)
I would say go with whatever is a stock ECU for the H22 but I think the p28 will work just fine, and there good ECU I used to have one. Good Luck Some guys on here have (p28) them and will chip them if needed and are really good. Look around
Old 09-23-2005, 03:11 PM
force-fed's Avatar
Default Re: h22 swap (TotaledHatch)
thanks bro
Old 09-23-2005, 03:15 PM
TypeRKoncepts's Avatar
P13 is the stock ecu, try to get one that matches the year of your h22a motor. If its a 92-95 h22a get an OBD1 p13 (out of a 92-95 prelude) and it shouldn't be a 96+ h22a motor anyway since your car is obd 1 (you would have realised some wiring issues with the distributor and engine harness)
P28 wont run the h22a well because it lacks control of the secondaries that are in the h22a intake manifold. Also a stock p28 wont run the prelude properly u'd need a p28 socketed and running an H22a map to have it run decent.
Old 09-23-2005, 03:29 PM
Former Sponsor
-Bionic-'s Avatar
Default Re: (TypeRKoncepts)
I believe the P28 is the ECU for Civics, while the P72 is the ECU for the integera.
The P13 is for the Prelude, H22.
Old 09-29-2005, 02:35 PM
force-fed's Avatar
Default Re: (-Bionic-)
So a p13 would be best, OK thanks guys!
Old 09-29-2005, 07:58 PM
Former Sponsor
-Bionic-'s Avatar
Default Re: (f22hafler)
For the H22; Yes.
Old 09-30-2005, 08:58 AM
h22accordfodo's Avatar
IMHO I like the chipped p28's the most (phearable.net) for the h22a , also running a v-afc w/ the p13 is nice... I have for sale a p13 ecu, v-afc, 450cc injectors and the p28 ecu tuned for the 450cc injectors <-- parted from the slightly used FULL turbo kit im selling for the h22a1 w/ rebuilt and polished t3/t04 turbo let me know if anyone is interested
732xghost
07-26-2007 03:03 PM
TN90accord
06-24-2006 12:19 PM
EDANSiR
04-14-2006 07:07 PM
kholmes
03-12-2005 06:23 AM
1.8T_EG
05-06-2003 09:20 AM
Quick Reply: h22 swap
