How can I disable the default security alarm? - Honda-Tech
Old 10-15-2005, 05:07 PM   #1
sL1cK's Avatar
Default How can I disable the default security alarm?
For some reason my car started going crazy last night when I went to fill up at a gas station. The default alarm that comes with the car started going off. The horn and lights were blazing and I could not stop it and had to drive home that way. It finally stopped when I got home. Is there a way to disable it until I can get it to the shop? TIA.
BTW, it's a 1999 Honda Accord.
sL1cK is offline   Reply With Quote
Old 10-15-2005, 05:10 PM   #2
P_Adams's Avatar
Default Re: How can I disable the default security alarm? (sL1cK)
If the '99 is like my '97, pull the Fuse marked "Security"
P
P_Adams is offline   Reply With Quote
Old 10-15-2005, 08:30 PM   #3
philadd's Avatar
Default Re: How can I disable the default security alarm? (P_Adams)
Quote:
P
You know, of all the times I've seen that fuse, I never thought of doing that. I'm going to have to try that right now. I have an aftermarket alarm, and my friends and the occasional valet like to lock the doors manually, thus arming the factory alarm.
BTW, next time the alarm is going off, all you have to do to stop the siren is to put the key in the driver's side lock and turn the key (lock or unlock, I can't remember). Make sure all the doors are closed first.
**EDIT**
Nevermind, I must have been smoking something, there's no fuse labeled for just the factory alarm on my '99.
Modified by philadd at 10:42 PM 10/15/2005
philadd is offline   Reply With Quote
Old 10-27-2005, 08:34 PM   #4
wakawaka44's Avatar
I havent found out how to do that yet but the alarm on my 02 accord goes off at random. Usually hitting lock and unlock on the remote works (replacing the remote battery seems to have made it more effective) It had a quiet mode with no beeps but that went away after I disconnected the battery to look at my stereo and I havent been able to get that back either. the booklet on the alarm is completely useless. Hopefully someone will know the secret and share it with us
wakawaka44 is offline   Reply With Quote
Audiovox alarm help mario98 Audio / Security / Video 5 05-18-2016 07:56 AM
Alarm enabled push to start button inh Audio / Security / Video 2 07-23-2008 01:52 PM
LS bad electric problem sydegsr Acura Integra 1 04-21-2007 07:46 AM
integra gsr 99 alarm wiseone Acura Integra 8 01-26-2007 09:20 AM
If your battery is dead, will your alarm still work? yung98gsr Acura Integra 7 04-28-2005 04:34 PM
Tags
1999, 2004, 97, 99, accord, alarm, disable, factory, fuse, honda, horn, quiet, remote, threads, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
