How to adjust idle on OBDII
Old 09-27-2005, 01:42 PM
kluckerz's Avatar
Default How to adjust idle on OBDII
Does anyone know how to adjust the idle on a '97 accord?
Old 09-27-2005, 02:30 PM
Bob Boberson's Avatar
Default Re: How to adjust idle on OBDII (kluckerz)
you cant (without computer tuning). Is it idleing high or low
Old 09-27-2005, 02:52 PM
Chiovnidca's Avatar
Default Re: How to adjust idle on OBDII (Bob Boberson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Boberson &raquo;</TD></TR><TR><TD CLASS="quote">you cant (without computer tuning). </TD></TR></TABLE>
Sure you can. Just turn the air bleed screw on the throttle body if you just want to bump it up or down a little.
Old 09-27-2005, 02:53 PM
Default Re: How to adjust idle on OBDII (Chiovnidca)
yea that will work until the iac compensates for it and brings it back to where it was
Old 09-27-2005, 03:25 PM
gianinline's Avatar
..isn't just a cable and a little screw.... I think that you CAN adjust it!!!
Old 09-27-2005, 04:34 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Boberson &raquo;</TD></TR><TR><TD CLASS="quote">yea that will work until the iac compensates for it and brings it back to where it was</TD></TR></TABLE>
What Chio said is correct , u can adjust the screw,,i have done it a zillion times with no problems ,,, turn it clockwise you lower it, counterclock raises the idle ..if you raise the idle too much the engine will surge ,, you waqnt to be at about 700-750
Old 09-27-2005, 06:10 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">What Chio said is correct </TD></TR></TABLE>
Your usually telling me i'm all f-ed up!!!
The iac will be commanded to take some of the adjustment back, but the ECU isn't smart enough in the 97 models to do it much.
Old 09-27-2005, 06:48 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Boberson &raquo;</TD></TR><TR><TD CLASS="quote">you cant (without computer tuning). Is it idleing high or low</TD></TR></TABLE>
Turn on the engine, disconnect the IAC then adjust the screw. Turn off the engine, plug back the IAC.
Old 09-27-2005, 11:02 PM
[QUOTE=Chiovnidca]
Yo Chio , i respect your abilities, you are 1 of the guys in this site that knows what he is talking about ...
Old 09-28-2005, 12:12 PM
kluckerz's Avatar
i did the screw thing by the TB and it didnt work.... it lowers it... but it wont bring it up.... im @ 500 rite now... and would like to bring it up around 800...
Old 09-28-2005, 01:40 PM
Chiovnidca's Avatar
Default Re: (kluckerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kluckerz &raquo;</TD></TR><TR><TD CLASS="quote">i did the screw thing by the TB and it didnt work.... it lowers it... but it wont bring it up.... im @ 500 rite now... and would like to bring it up around 800...</TD></TR></TABLE>
The passage could be partially clogged up with crud. Try taking the bleed screw out and hosing the hole out with t/b cleaner.
90_civic_Si
10-04-2006 08:36 PM
hatchfreak92
10-17-2004 08:59 PM
korndog
09-14-2004 05:59 AM
JCCOOL43
06-13-2003 03:15 AM
niedejb
02-13-2003 01:47 PM
Quick Reply: How to adjust idle on OBDII
