Hot air coming through the vents (90 Accord)
While driving a Honda I bought I noticed that there is hot air seeping through the vents. Neither the A/C or Defrost or any of the air controls are turned on and the **** is actually set to cold. The A/C doesn't even work on the car. The light and fan works but no cold air. My main concern is seeing if someone can help me figure out why there is hot air coming through the vents while driving the car. Thanks for your help!
Re: (quizbo99)
to get the ducting out you need to pull the dash, than right behind the middle part is going to be all the doors to send air the vents and stuff. you can reseal them with cheap foam with double sticky tape. or you can not spend 3 hours on something that may or may not work and roll your windows down
Re: Hot air coming through the vents (quizbo99)
I would suggest that you could check that the heater control valve, [underhood near the firewall] sometimes the cable is out of adjustment and allows hot coolant to seep thru the heater core.
Re: Hot air coming through the vents (Mr Yamada)
Set the system to recirculate instead of fresh air. That should keep the hot air from coming in from the engine bay.
Re: Hot air coming through the vents (propwdialogue)
^^^^^^^^ X2
That makes a difference. Even if the **** is set on cold and on off and its set on outside air it will always blow warm air into the car while driving.
Before going and fixing all the seals and everything make sure its not just something simple, my thought: make sure the button on the dash is set to the recycle air feature then because if it is set to fresh air no matter if the a/c or anything like that is on air will come through those vents and if its hot outside it'll be hot air coming through if its cold outside (depending on the engines temperature) you'll get cold air...
Sorry if that's doesent work for you, cause after that I dunno what else to do haha
Atalbot20
03-31-2018 09:32 AM
