Hood has the shakes
Old 08-28-2010, 04:25 PM
runderwo's Avatar
Default Hood has the shakes
Ok, I have 6 rubber pieces (4 in front, 2 on the sides) in place, and I have replaced the hood latch. The hood stays securely in place in the middle but shakes visibly on the sides while driving and makes noise. What's the best way to fix it, am I missing some rubber on the hood or something? I don't see anything on this diagram:
http://www.hondaautomotiveparts.com/...&catcgry5=HOOD
Old 08-28-2010, 05:08 PM
9450erick's Avatar
Default Re: Hood has the shakes
the actual rubber pieces move up and down if u twist them. you could try raising the rubber pieces so the hodd actually rests on the rubber pieces
Old 08-28-2010, 06:32 PM
runderwo's Avatar
Yeah, I tried that. But even if I unscrew them as far as they can go without coming out, it still seems like there is something missing along the left and right edges that should be underneath the hood and keeping it from shaking back and forth. Couldn't find anything obvious on the junkyard cars.
Old 09-01-2010, 01:22 AM
9450erick's Avatar
is your hood even with the fenders.
i know in my car you can adjust the hieght of the latch (99 accord)
my hood was really high and it shook from side to side as well/ also made a bad screaching noise.
then i found out i can lower the latch and now the hood rests on the rubber things, doesnt make that noise anymore, looks even with the fenders, and doesnt move from side to side anymore
Old 09-01-2010, 04:42 AM
runderwo's Avatar
That's the weird thing. It's even with the fenders, but it's not resting on the rubber things that go into the holes on the top of the fenders, one on each side.
Old 09-01-2010, 04:58 AM
nhldogg's Avatar
Are your motor mounts okay? I had a friend with a bad motor mount whose hood would shake / vibrate really loudly when at an idle or when driving once he replaced the broken mount it stopped.
Old 09-01-2010, 05:20 AM
runderwo's Avatar
Hmm, I guess it's worth a check. I just replaced the dog bone mount in the front because it was rotten.
Old 09-01-2010, 05:49 AM
nhldogg's Avatar
Yeah i would defently check the others and make sure that the one you installed was installed correctly.
Old 10-12-2010, 10:20 AM
runderwo's Avatar
Mounts are good. Could someone do me a favor and go and push down on the very edge of your hood about midway between the windshield and nose of the car? And tell me what is keeping the hood solid and not letting it push down at that particular point? I have a square hole on each side that it seems like a rubber piece of some sort could pop into, but I have not been able to locate such a piece on any junkyard car.
Old 10-12-2010, 10:25 AM
He knows where you live!
TheMuffinMan's Avatar
How does the alignment look at the front? You may have to adjust your hood latch downwards.
Also is this a metal/OEM hood? Or is this a fiberglass/carbon fiber?
Old 10-12-2010, 12:37 PM
runderwo's Avatar
The alignment looks great. It's right on, at least if the hood is supposed to look level with the fenders. I don't know about the composition, but it seems like metal and has never been replaced to my knowledge.
Old 10-13-2010, 09:16 AM
Dannyvho's Avatar
On each fender about halfway between the windshield and the front of the fender there's a rubber part described as 'cushion, hood side', part# 74146-SM4-000 (sorry, I can't display the page you refer to in your OP)
Old 10-13-2010, 09:19 AM
runderwo's Avatar
OK, I have those. I wonder why there is a gap, none of this is making any sense. If the hood itself is flush with the fenders then those two rubber pieces should be supporting the hood on the sides.
Old 10-13-2010, 09:34 AM
Dannyvho's Avatar
Any chance these rubber parts are cracked or worn out? Like you said they should be supporting the hood when the sides are flush with the fenders. You could attach little rubber pads to the bottom side of the hood to make the hood sides rest on these 'cushions'.
Old 10-13-2010, 10:50 AM
runderwo's Avatar
I'll check for cracks. Yeah, I'm ready now to just "make it work". I wanted to be sure I wasn't missing something completely obvious first.
Old 10-13-2010, 04:48 PM
poorman212's Avatar
Can I ask why the hood was replaced to begin with? Something bent. With the hinge off-how does is lay on the stops....could the latch be pushed back creating the bow in the middle.
Old 10-13-2010, 04:56 PM
runderwo's Avatar
The hood wasn't replaced, just the latch because of this problem. I noticed there was play in the latch and replaced it because I thought it was the cause. Now there is no play in the latch but the hood still shakes. I'll take a closer look at how the latch sits and see if anything looks funny.
Old 11-14-2010, 05:02 PM
runderwo's Avatar
Are there supposed to be any rubber pieces in the hood itself? i.e. facing downwards
kyle92integ
05-28-2005 01:34 PM
alias 33
07-21-2004 03:23 PM
t0ekn3e
07-09-2004 11:27 PM
Nighthawk GS-R
10-26-2003 10:43 AM
Quick Reply: Hood has the shakes
