Honda Accord ( Needs new IACV )
Old 07-03-2010, 11:10 PM
sherwo_od's Avatar
Default Honda Accord ( Needs new IACV )
I'm buying an 89 Honda accord that runs pretty good except its idle hops up and down a bit and he thinks its the Internal air control valve. It also sometimes doesnt start unless you hold the key on for a good 5-10 seconds. I was reading some where that that could be a sign of needing a new IACV as well.
Do you guys think this would fix the issue? I think this is the part http://www.autozone.com/autozone/par...24324_0_10703_
Old 07-03-2010, 11:15 PM
phootbag's Avatar
Default Re: Honda Accord ( Needs new IACV )
Could be one or more of numerous possibilities. The Idle Air Control Valve can get gummed up and not respond to commands causing this symptom. A stuck open PCV can do the same thing. Long cranks could be unrelated to the idle issue.
shawn davis
09-10-2018 07:16 AM
Gr8ride82
01-26-2015 04:31 PM
WestSideRain
05-27-2010 08:39 AM
Choc-Thunder
10-25-2009 02:46 PM
Brandonf22
02-20-2008 06:50 PM
Quick Reply: Honda Accord ( Needs new IACV )
