Honda Accord EGR Valve
Testing Ported EGR Valve
1. Run engine to operating temperature and allow it to idle. Attach a vacuum gauge to EGR vacuum hose. Locate EGR vacuum solenoid.
2. Using a jumper wire, ground signal wire from ECM to EGR vacuum solenoid. Vacuum should be present at EGR vacuum hose. On some models, engine speed may have to be increased 3000-4000 RPM.
3. Connect a vacuum pump to EGR valve. Start engine. Apply vacuum to EGR valve. If engine runs rough or stalls, and gauge holds vacuum, EGR valve is functioning properly.
To see the original article with images check it out here: Honda Accord EGR Valve. Garage411.com
swertepinoy
10-12-2009 02:50 PM
