f22 knock
Old 08-04-2011, 03:27 PM
stretchum's Avatar
Default f22 knock
ok guys i have a quick question. why is it that the f22 in my 91 cb has a knock to it? i recently had all fluids changed and the plugs it only has 90 thousand miles on it. but i have a 97 ek hatch d15 and it dont knock at all with 164xxx on it. is it just that series motor or is it a sign that something is about to mess up
Old 08-04-2011, 08:07 PM
nus_dogg's Avatar
Default Re: f22 knock
Does it knock when the engines hot or just when it's cold? Is the knock consistent with the engine RPM or slower??
Old 08-05-2011, 02:15 AM
MM Gruppe B
MAD_MIKE's Avatar
To expand on this a little further.
If the engine constantly knocks, and the timing of the camshaft and distributor are in spec, then it could possibly be a bad rod or crank bearing.
However, if the knocking only occurs while cruising ~2000rpm then it may just be your EGR ports/valve are carbon clogged. A common enough problem when it comes to F22s.
Use a broom handle, large screwdriver, or extension from the engine to your ear to identify that it is indeed the engine making the knocking sound. Sometimes a faulty PS pump can make a hell of a racket under hood.
Old 08-05-2011, 05:48 AM
stretchum's Avatar
Ok its knocking from under the valve cover and its bad as soon as you crank it but it mellows out as the motor warms but it always has a knock to it
Old 08-07-2011, 11:54 PM
MM Gruppe B
MAD_MIKE's Avatar
A knock or clack? If its clacking you will need to adjust the valves.
Old 08-08-2011, 04:58 PM
stretchum's Avatar
that may be it then cuz it's sounds like a little tractor when you first turn it on
si GReedy
03-19-2014 05:59 PM
nece228
09-01-2012 01:16 AM
d17a1n00b
Honda Civic (2001 - 2005)
10-02-2009 08:58 AM
Pompiuses
03-14-2006 11:13 PM
I8ayellowcrayon
10-04-2003 09:41 PM
Quick Reply: f22 knock
