Honda Accord 97 V4 cigarette lighter outlet not working
Old 09-07-2013, 06:32 PM
ChristianOrtiz's Avatar
Icon2 Honda Accord 97 V4 cigarette lighter outlet not working
So I've noticed that the cars outlet does not work, I did some research and found that it might be a fuse, but my question is how do I check the fuse, like where is it located? I know it's that cause I've plugged a few chargers and none of them work
Old 09-07-2013, 11:25 PM
holmesnmanny's Avatar
Default Re: Honda Accord 97 V4 cigarette lighter outlet not working
There is no such thing as a v4.
Some people actually disconnect the power wire to the cigarette lighter. If you can take out the radio and physically confirm that the power wire is actually attached to the lighter that would be your first thing to check.
Old 09-08-2013, 03:50 AM
Lost Again's Avatar
Fuse should be #11 (10 amp) in the drivers under dash fuse box. If you have the factory radio, that same fuse "feeds" the radio as well....so if the radio (factory set up) is working then the fuse is fine.
From there, "holmes" has already answered the question.
Old 09-08-2013, 08:21 AM
Global Moderator
tech8's Avatar
To access the cigarette lighter wiring and relay, the console needs to be removed; however, the radio does not necessarily need to be removed.
Old 09-08-2013, 08:48 AM
augustus's Avatar
false, but they are not common:
http://en.wikipedia.org/wiki/V4_engine
Old 09-08-2013, 12:48 PM
Lost Again's Avatar
Originally Posted by tech8
You should still check fuse number 11 in the under-dash fuse box. The fuse number 11 protects the cigarette lighter relay.
Sir, it could be the bad manual I have but doesn't the radio also "feed" off the "lighter relay"?
Old 09-08-2013, 01:17 PM
Global Moderator
tech8's Avatar
Yes, I looked at the stereo circuit diagram I had. The wire coming from under-hood fuse 36 is hot at all times and provides power to the cigarette lighter relay (the relay is normally open). When the ignition switch is turned to ACC or ON, this provides power via the under-dash fuse 11 to energize the cigarette lighter relay, which closes the relay and provides power to the cigarette lighter and stereo.
So, in conclusion, if the stock stereo works, both fuse 36 and 11 should be okay. Therefore, if stock stereo works, it probably comes down to the wiring or lighter socket.
Old 09-09-2013, 04:54 PM
Lost Again's Avatar
Thanks, that is where I was going.
Old 09-14-2013, 09:28 AM
my box does not say anything with cigarette lighter, just radio motor antenna and heater, it has other things but I don't think is related to what I'm looking for
Old 09-14-2013, 09:38 AM
S2Integra's Avatar
Default Re: Honda Accord 97 V6 cigarette lighter outlet not working
you could pull and check every fuse if your stumped. If it isn't a fuse I'd check the leads to the lighter as previously mentioned. It will require a good amount of time though.
Old 09-14-2013, 10:05 AM
[IMG]www.dropbox.com/sc/0zz46b9gfzuk02d/xu-7YDHpGL[/IMG]
i got these two but i dont know which one is the fuse for the cigarette lighter, help ?
Old 09-14-2013, 10:06 AM
Old 09-14-2013, 10:35 AM
NZXTInerTia's Avatar
Your radio fuse is your cigarette lighter fuse dude.
jwinthrop
12-31-2012 05:27 AM
Stover954rr
Audio / Security / Video
07-31-2012 03:09 PM
19Accord97
07-15-2011 05:57 AM
boostedefhatch
07-10-2009 12:15 PM
pinkspider
10-23-2006 02:11 PM
Quick Reply: Honda Accord 97 V4 cigarette lighter outlet not working
