Honda Accord 2000 - Intermittent issue - Engine Light ON / Jerks on 3k revs - Honda-Tech
Old 08-11-2010, 01:43 AM   #1
Icon2 Honda Accord 2000 - Intermittent issue - Engine Light ON / Jerks on 3k revs
I have a Honda Accord 2000 1.8 that runs fine. However every once in a while the engine management light comes on (not flashing).
Once this is on the car can not top 3k revs and it starts jerking. Even on neutral when you put your foot down the engine jerks.
Engine also stalls during the drive, which is dangerous as steering gets jam. Starting car again works but I have noticed in those cases the fuel guage goes to E and light comes on (even though before stalling it was showing correctly half a tank). The idle revs are also too low. Are these two problems sign of something else wrong? Something with fuel injection?
One suspect was CAT which a garage tested for me and it is fine. Another garage tested for the code and it came out P1607.
I was told that the Engine Control Module is at fault and it needed to be sent away for either repair or replacement.
Cost around 300~400 pounds in both cases.
Just wanted to know if this is what might be it or I could be out of pocket for this money with fault still there.
Any questions please ask me.
Thanks in advance for any help.
kubafle is offline   Reply With Quote
Old 08-11-2010, 05:45 AM   #2
Default Re: Honda Accord 2000 - Intermittent issue - Engine Light ON / Jerks on 3k revs
If your are getting a p1607 code its time to change your computer, which motor do you have f23a1 or f23a4?
6GA/CG3 is offline   Reply With Quote
Old 08-11-2010, 05:52 AM   #3
Hi,
thanks for quick reply.
I checked the FAQ as below and could not find that how I can find if it is f23a1 or f23a4.
http://honda-tech.com/showthread.php?t=1664547
Can somebody point me to info on how do I find this?
Old 08-16-2010, 06:55 PM   #4
Very well could be the ECU, I'd make sure to get a pressure reading from your fuel pump as well. The F23a1 motor turns vtec on at 2500rpm, maybe it's trying to advance timing too much or little and chugging along, idk. BTW you don't have a 1.8, you either have a 2.3li or 3.0v6, unless you did some kind of 1.8li engine swap.
draco751 is offline   Reply With Quote
Old 08-17-2010, 01:24 AM   #5
hey draco751,
It is a Euro model (I am here in Queen's land)
The engine is F18B2.
Rest of details:
ACCORD I-VTEC SE (MK6)
Engine Size 1850 cc
Manufactured 2000
Transmission MANUAL
However a couple of people have suspected fuel system at fault. I will get it checked/fixed as it is much cheaper than ECM thing.
Something strange I found out that when I took it to first garage who checked CAT was because they could not find the plug to check engine code. Even though the manual says it should be under the carpet on passenger side it is no where to be found.
Then it was this second garage who gave me code P1607.
Now just to confirm that it is the right code I took it this weekend to two garages and both could not find the plug to check engine code.
I am now wondering where did P1607 code came in from and how was it received without the plug. It is suspected that it was either never fitted or removed/pushed in dashboard after wards.
Any other way for checking Engine code?
Jerking and sometimes stalling when come to stop?? Kozlo22 Honda Civic (2001 - 2005) 3 08-24-2015 01:55 PM
HELP!!!!!!!!!!! frustrated Fit Honda Fit 1 11-28-2014 07:50 PM
Honda Accord v6 2000 auto stalling alex-accord Honda Accord (1990 - 2002) 5 09-15-2013 12:53 PM
2000 Si/SiR Engine stumbles and stalls akdrag Honda Civic / Del Sol (1992 - 2000) 6 04-21-2007 01:33 AM
2000 civic si stalling b00mz Honda Civic / Del Sol (1992 - 2000) 3 03-29-2002 12:40 PM
Tags
04, 2000, 2000changing, accord, car, computer, control, engine, honda, jerk, jerking, jerks, light, module, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
