honda accord 2000 car alarm - Honda-Tech
Old 05-14-2007, 01:23 PM   #1
mila's Avatar
Default honda accord 2000 car alarm disarm
My car alarm sounds at all times of the day for no reason. the only way I can turn it off is by putting the key in the ignition to turn the car on or I just let it go until it stops by itself. The alarm also almost always sounds after I have unlocked and entered the car just before I start the car. My remote does not work to shut the alarm off, yet I can still use it to open the trunk.
Has anyone else had this problem?
And how can it be fixed?
How can I temproraily disarm the alarm that came with the car when I bought it in 2000?
thanks for any help on this...
mila is offline   Reply With Quote
Old 05-14-2007, 02:19 PM   #2
rossodsm's Avatar
Default Re: honda accord 2000 car alarm disarm (mila)
Sometimes those alarms malfunction, you have to reset it by disconnecting the battery, but i'm not to familiar with stock alarms.
rossodsm is offline   Reply With Quote
Old 05-14-2007, 03:57 PM   #3
power11's Avatar
Default Re: honda accord 2000 car alarm disarm (rossodsm)
or. you can put your key into the drivers side lock and turn it left then right and it should reset and turn off.
power11 is offline   Reply With Quote
Old 05-15-2007, 01:25 PM   #4
mila's Avatar
thanks for the suggestion, ill try to disconnect the battery, i'll try anything at this point.
Old 05-15-2007, 01:28 PM   #5
mila's Avatar
Default Re: honda accord 2000 car alarm disarm (power11)
ive tried to put the key in the driver's side lock and turn it left then right, unfortunately that doesnt work....thanks though...ill report back when i finally figure it out so that hopefully other people that may have this problem can be helped....
Old 05-15-2007, 03:35 PM   #6
try resetting the multiplex unit on the car by
setting the intermittent wiper ring to the middle position
turn every accessory off
turn the car to the on position and do not start
YeuEmMaiMai is offline   Reply With Quote
Old 06-06-2007, 05:03 PM   #7
mila's Avatar
I disconnected the battery and , yes, that worked great. the alarm doesnt go off anymore at strange times for no reason!
Thanks so much.
I seem to have isolated the problem also.
It seems as though there is something wrong with the sensors/wiring to the alarm from the car seat, when i sit or press on the car seat this activates the alarm when it shouldnt be activated. Will have to look into the exact problem. But for now I am grateful that the alarm doesnt go off while sitting in the drive for no reason.
thanks again
car alarm problem bgizzle33 Audio / Security / Video 4 01-19-2009 07:02 AM
alarm question---noob turbosiek9 Audio / Security / Video 2 01-15-2009 01:59 PM
accord 2000 car alarm problems mila Audio / Security / Video 1 05-14-2007 01:38 PM
94 honda accord ex factory alarm system silverado Honda Accord (1990 - 2002) 0 03-11-2006 10:53 AM
ignition problem:aftermarket alarm jameskersten1 Honda Civic / Del Sol (1992 - 2000) 4 05-24-2004 10:58 PM
Tags
2000, 2002, accord, alarm, car, disarm, disconnect, disconnecting, honda, malfunction, malfunctioning, reason, reset, sounds, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
