hi, i'm having a problem with the ABS light on. Need Some ADvice/
every time i turned on my car and went for about 5 second the ABS' light on the brake is working fine, i have no problem with that... I want to ask u what might cause the ABS's light on? u think maybe there's some leaking but i don't know.....
Re: hi, i'm having a problem with the ABS light on. Need Some ADvice/ (maivietla)
i once drove my accord w/o completely releasing the e-brake and the abs light came on.. it reset when i turned the car off and restarted it.. but that might be something.. check the fluid levels, and the e-brake cable(make sure it isn't stuck anywhere) good luck
yea its probably leaking....i didnt notice the deterioration in brake performance at first but after ignoring the light for a WHILE haha it became really dangerous i could barely stop....its most likely your calipers get them checked out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maivietla »</TD></TR><TR><TD CLASS="quote">every time i turned on my car and went for about 5 second the ABS' light on the brake is working fine, i have no problem with that... I want to ask u what might cause the ABS's light on? u think maybe there's some leaking but i don't know.....</TD></TR></TABLE>
check the abs reservoir to see if theres even any fluid inside there... if not just fill it up and see if your problem goes away... if not get a voltmeter and check the wheel sensors make sure their alrite before you go throwing $ into replacing em...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">Year? Model? Please move a little to the left. I can't see your car.</TD></TR></TABLE>It's interesting the answers you get, since the ABS systems are so different over the years. Newer ones don't even HAVE an ABS fluid reservoir...
Ruskimafia
12-05-2005 06:08 PM
