More torque
Old 02-24-2011, 11:43 AM
Fendyc718's Avatar
Default More torque
I have a 2001 Accord F23A1 2.3l 4Cyl Automatic, i was wondering if their is a way for me to get more torque out of it. is it possible or since its an auto it wont really go up. any tips or suggestions is appreciated
Old 02-24-2011, 05:00 PM
nicolaselias's Avatar
Default Re: More torque
anything that will give more power will generally give you more torque...
Upgraded cams and valvetrain, intake, header, exhaust, better intake manifold etc
Just read up and know your going to have to spend $$$ for gains
Old 02-24-2011, 05:17 PM
preludebro's Avatar
TURBO!
chipped ecu... bigger injectors, engine bore and more
Old 02-24-2011, 06:40 PM
SHAME ON YOU REBECCA!
kidcool1977's Avatar
TQ = $$$$
With that said how deep are your pockets, if they are deep set up a budget and you'll get all the TQ beyond your wildest dreams.
Or you can just buy another car.
Old 02-24-2011, 07:09 PM
wolfy47's Avatar
not really tq but you can do shorter gearing
Old 02-24-2011, 07:58 PM
nus_dogg's Avatar
This will be a hard one w/o major modification if you want torque.
Old 02-25-2011, 04:36 AM
hondamark35's Avatar
almost every "power" upgrade on the market is really either a torque shifter (usually towards the higher RPM) or a torque increaser.
torque is a measurement. power is the result of a calculation based on torque.
it's fair to say though that when we talk about a "torquey" motor, we mean one with a lot of low-mid range torque. congratulations OP, the F23A1 is already optimized for that. the only problem is it's strapped to a heavy car... a mild build with exhaust, a nice cam regrind and other supporting mods should show some improvement. don't cheap out on the dyno tune though. this is where you can really dial it in to shift that torque curve lower. of course realize this will adversely effect you're high RPM output some... and of course a turbo would really show the biggest torque gains.
either way you go, that auto trans won't like anything extra. if it were me i would tackle that first. either swap transmissions or swap cars for a manual equipped Accord.
Old 03-08-2011, 05:33 PM
Fendyc718's Avatar
I was looking at these cam gears and was wondering if they would fit on my car it say their for an h22 or an f20b is that a big difference or are those parts interchangeable with no problem.
http://www.theboombopshop.com/Skunk2...04-05-0225.htm
Old 03-08-2011, 06:13 PM
specialone70's Avatar
anything you can do to lighten the power train will help. if you had a manual i would say aluminum fly wheel, but idk what you do with an automatic.
Old 03-09-2011, 03:11 AM
they won't interchange. what will fit is one for a SOHC F-series VTEC (F23A1, F22B1..)
why do you need an adjustable cam gear? did you get a cam?
torque converter with a higher stall speed...? i was going to say "if anyone makes that.." before i found this site that's a bunch of money compared to going self-shift!
Old 03-09-2011, 04:24 AM
uberEFtuner's Avatar
You need to get a 5 speed. I did a header on my automatic accord, and I couldn't feel any difference. I did a header on my 5 speed civic and it was a noticeable bump in performance! AUTO SUCKS
Old 03-09-2011, 04:40 AM
He knows where you live!
TheMuffinMan's Avatar
butt dyno != real dyno
Accords really don't respond well to the I/H/E modifications as much as some other vehicles. To get actual power you have to do those coupled with like a camshaft and cam gear as well as tuning (maybe an upgraded valve train as well.)
Getting the car back up to 100% maintenance wise will help out, like when was the last time the transmission fluid was changed?
I've actually seen a turbo-charged 98-02 V6 (auto obviously) which apparently ran okay. I wouldn't do it myself but whatever, it can be done.
Getting a camshaft, camgear, quality I/H/E and running a VAFC or something similar would probably help quite a bit. Because you're OBDII and automatic though it complicates the tuning I'd imagine.
Old 04-12-2011, 11:31 AM
Fendyc718's Avatar
hey im back with this one what do you guys think about under drive pulleys. worth it or not for some gains
Old 04-12-2011, 11:41 AM
just the pulleys alone?
Old 04-12-2011, 06:39 PM
gogydm's Avatar
You are going to be underdriving all of your components and they are going to wear out sooner. Buy them only if they are lightweight but don't underdrive. You probably won't feel much improvement from them though. Wasn't there a supercharger for the f23?
Old 04-13-2011, 09:28 AM
Fendyc718's Avatar
na not that i have seen iv looked around for a bit. if you know of a site i can look more up on it. it would be appreciated
diversegsr
01-21-2010 07:42 AM
Bitchin_Teg
10-08-2005 08:23 PM
pbink
09-22-2005 12:05 PM
spaghizzle
05-01-2003 07:11 PM
Integra187
07-16-2001 07:09 PM
Quick Reply: More torque
