Help: H22A 4th Gen Accord ECU wiring.... - Honda-Tech
Old 08-28-2002, 01:51 AM   #1
StickyDilJoe's Avatar
Default Help: H22A 4th Gen Accord ECU wiring....
Hi all, I'm new here. I recently purchased my JDM 93 H22A motor/tranny/ecu from HondaMotorsOnline. Everything else, besides some issues of wear/tear and rust from the Accord being old, it's coming along well. What I need help with is the ECU wiring for the motor to the P13 ECU because the harness was and still is cut. I've been told that the VTEC Solenoid, VTEC Pressure Switch, IAB, and Knock Sensor wires have to be added to accomodate the swap. I'm a genuine Toyota tuner at heart and I haven't figured out why the wires have to be added if I'm running an H22A motor with H22A ECU. If anyone has done their own swap and has a detailed description as to how and why this is done, I would greatly appreciate it. I would really like to know how to do the wiring to get everything running right. The basic in's and out's of both motors I understand, it's the wiring that's got my stumped. Thanks in advance for helping.....
StickyDilJoe is offline   Reply With Quote
Old 08-28-2002, 01:52 AM   #2
Accord94DX's Avatar
Default Re: Help: H22A 4th Gen Accord ECU wiring.... (StickyDilJoe)
hi. it is a lovely night, huh?
http://www.honda-tech.com/zerothread?id=223138
Accord94DX is offline   Reply With Quote
Old 08-28-2002, 02:02 AM   #3
Default Re: Help: H22A 4th Gen Accord ECU wiring.... (Accord94DX)
It'd be a better night if I figured out this wiring harness...
I actually have that thread bookmarked. I have reason to believe that I suffer from mild retardation because I don't really understand it even after reading that thread about 4-5 times. I'm also running (or was running) an Accord EX ECU and harness. Still don't understand why wires have to be added if I'm running the ECU from the same engine.... Still confused...
Old 08-28-2002, 02:06 AM   #4
Accord94DX's Avatar
el peepo thiso.....i wish i could help, but i like nitrous and f22b2s better.
http://www.h22a.org/4gswap.htm
Old 08-28-2002, 02:09 AM   #5
I also have that bookmarked but sadly, that was even harder to understand. I'm new to the Honda scene, things are very different here.
Old 08-28-2002, 02:12 AM   #6
Accord94DX's Avatar
I understand your frustration. Dave (4doorh22) will most definitly be able to solve your problem. However, I don't think he is online at 4:24am.
Old 08-28-2002, 02:20 AM   #7
Yeah, I'm sure someone can. I had no idea so many people had done the swap already....
Old 08-28-2002, 11:14 AM   #8
just plug in your stock harness everywhere it fits...there should be a few extra sensors/solinoids you need to add wires to and wire them straight to the ecu...knock sensor, 2 vtec wires...and one vtec ground....and i think you should be good from there
H23 Power is offline   Reply With Quote
Old 08-28-2002, 09:23 PM   #9
Default Re: Help: H22A 4th Gen Accord ECU wiring.... (F23 Power)
on my p3 dx swap, i had to add the vtec solenoid, vtec pressure switch, and knock sensor wires to my ecu. i am running a 95 jdm h22 with a p13 ecu. i used my old acord dx wiring harness. first off, my old harness did not have vtec wires, so i had to add those two. also, the old f22 didnt have a knock sensor either, so i had to wire that to the ecu. im not sure if the ex motor had a knock sensor, but if it does, then just find out what color the wire is, and make sure it is in the right pin for the ecu. you need to get a wiring diagram of both ecu's to double check that the wires match up. yours was an ex, so all you have to do is look up the wire color to the ecu from your old ecu, and make sure that it is the same on the p13, if not, move it to the right one. you dont have to add new vtec wires.
scrubachu is offline   Reply With Quote
Old 08-29-2002, 02:36 AM   #10
Default Re: Help: H22A 4th Gen Accord ECU wiring.... (scrubachu)
4th gen EX's dont have vtec so he will need to add the wires for VTEC and the knock sensor
94 Accord H23A Vtec Swap Thread Scott Little Honda Accord (1990 - 2002) 105 02-21-2017 06:47 PM
h22a1 into h23a1 si swap (93') 93blulude Honda Prelude 5 07-04-2008 06:02 AM
f22b1 into 1993 accord eg6_rick Honda Accord (1990 - 2002) 8 12-02-2006 10:55 PM
h22a ecu.. need help! Honda_hatch 96 Honda Accord (1990 - 2002) 2 06-01-2004 09:54 AM
new h22 in eg swap ?s boostindoo Hybrid / Engine Swaps 2 03-25-2003 11:01 AM
Tags
accord, cb7, chula, diagram, ecu, h22a, h23, harness, honda, p13, stickydiljoe, swap, vista, vtec, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
