Help with ABS intermittent ABS light. - Honda-Tech
Old 10-16-2008, 12:36 PM   #1
b18LS's Avatar
Default Help with ABS intermittent ABS light.
Hi guys, trying to diagnose my Dads '97 Accord with ABS. I've removed all 4 ABS sensors cleaned and replaced them. I've bled the front brakes, and will be doing the rear once we've got replacement bleed screws.
Is there a secret to bleeding the actual ABS unit? Is ti possible? The ABS light still comes on when youve been driving for a while and stomp on the brakes. It pulses a bit as well under light load. any thoughts?
Thanks for the help.
Ryan
b18LS is offline   Reply With Quote
Old 10-16-2008, 03:29 PM   #2
hondadude's Avatar
Default Re: Help with ABS intermittent ABS light. (b18LS)
Yes it is possible to bleed the pump/accumulator unit, there is a nipple fitting on it you can attach a tube to it and catch the old brake fluid into an old oil bottle.
You'll need a really tiny funnel to keep the ABS reservoir topped off.
Don't fully open the bleed screw [HIGH PRESSURE]
Turn the key on to repressurize the pump unit, between draining/bleeding.
Brake pedal pulsing under a light pressure is probably not the ABS.
I would think warped rotors the most likely cause.
Remember brake fluid will eat paint, clean up any spills with brake cleaner spray ASAP
hondadude is offline   Reply With Quote
Old 10-16-2008, 04:35 PM   #3
b18LS's Avatar
Default Re: Help with ABS intermittent ABS light. (hondadude)
Thanks for the reply! I'll give that a shot when I see the folks on the weekend.
Much appreciated.
Old 10-17-2008, 12:30 PM   #4
Duane_in_Japan's Avatar
It would be nice to know the code that gets set when the light comes on, I will say that the problem fixes itself so it self terminates the light, I would guess that it is pressure related, not WSS related.
Duane_in_Japan is offline   Reply With Quote
Old 10-25-2008, 10:55 AM   #5
gotusukin's Avatar
i have a 97 accord 2dr coupe 5speed..
wen i pull off my abs light goes on and stays on and if off wen i brake it will pulsate den light will come on to help brake.
Is there sumthing i should check to find out wat it might be.
gotusukin is offline   Reply With Quote
Bleeding after ABS pump/modulator replacement - 1994 civic SI weatherall123 Honda Civic / Del Sol (1992 - 2000) 9 02-09-2015 04:49 AM
ABS, but not ABS bleeding. jasonlindeke Honda Civic / Del Sol (1992 - 2000) 0 03-09-2014 06:07 PM
Bleeding ABS Pump Manually GaRn Honda Prelude 4 06-11-2009 08:21 AM
94 Accord ABS HELP!!!! skibum Honda Accord (1990 - 2002) 3 12-20-2007 05:15 PM
95 gsr with 5 lug ABS PROBLEM nosmas Acura Integra 1 07-29-2002 11:47 PM
Tags
2000, 2003, 92, abs, accord, acura, honda, intermitten, intermittent, intermittently, light, paint, prelude, rotor, rsx, warped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
