!HELP! - 1992 Accord EX Wagon won't start
Old 12-18-2011, 10:22 PM
ProchargerEM1's Avatar
Icon2 !HELP! - 1992 Accord EX Wagon won't start
Hello. I am currently having a starting problem with my 1992 Accord EX Wagon. About a week ago I replace my thermostat because I was no receiving heat in the cabin of the vehicle. After replacing the thermostat I tried to start the vehicle but it wouldn’t start; the engine cranks over as usual but just does not start. It had been a while since I changed the spark plugs so I installed new ones (there was some oil in the spark plug tubes – I am guessing was caused from the vehicles leaking valve cover gasket). After installing the new spark plugs the vehicle still wouldn’t start.
Today I had some free time so I began trying to get this vehicle running. In the past I had an ignition issue with this vehicle. It died on me while I was driving it. I had it towed to the local Honda dealer and they diagnosed it to have a non-functioning ignition igniter. I performed the diagnosis procedure for the ignition igniter as described in a Haynes Repair Manual and the ignition igniter failed. After replacing the ignition igniter, distributor cap and distributor rotor today the vehicle still does not start. Right now I am thinking that the ignition coil may be faulty.
I have also checked to see if there are any loose or disconnected grounds. All grounds are tidy and secure.
Has anybody ever experience a situation like this? I am getting older and losing patience trying to trouble shoot things. Any help would be greatly appreciated.
Old 12-18-2011, 11:19 PM
seanbev24's Avatar
Default Re: !HELP! - 1992 Accord EX Wagon won't start
Did you remember to bolt the ground wire back on to the thermostat housing?
Old 12-19-2011, 12:16 AM
Thanks pointing that out and the fast reply. Should this ground wire that you mentioned be a single wire with a ring terminal that grounds to one of the mounting bolts for the thermostat housing?
Old 12-20-2011, 07:42 PM
seanbev24's Avatar
It doesn't use one of the mounting bolts. There should be threads for a seperate bolt for the ground on top of the housing. I think for that ground, it's a few wires that come together in a ring terminal.
Old 12-27-2011, 11:59 AM
tymeclock's Avatar
Hey dude, I was itching to answer that problem but some one beat me to it. That ground wire cost me four hundred fifty dollars and a lesson in paying attention to details. I thought it was the electrical system first. I replaced the distributor, fuel pump, spark plugs, and wires and last the not least buying tools to do all of this. I own a 1993 Honda accord ex, seems like the Haynes manual would have mention this but I got some very needed experience. Did you ever get it fixed?
Old 12-27-2011, 12:06 PM
tymeclock's Avatar
o' yea, I also had to walk twelve miles to and from work, like I said, a lesson in paying attention.I only wish that I knew about this forum before, the site is full of good knowledge just for me kinda hard to find.
Old 12-31-2011, 01:37 PM
seanbev24 - Thank you for that added information that you provided. I have been trying to make time to get back and work on this no start problem but with the recent holidays I have just had to postpone it.
tymeclock - Was your no start problem the exact same scenario that I had described?
Bienval23
08-18-2014 12:14 PM
nc2wheels
01-23-2013 11:11 AM
michaelb15
12-06-2012 01:42 PM
nsxxtreme
04-08-2009 02:51 PM
Quick Reply: !HELP! - 1992 Accord EX Wagon won't start
