Heater (vents) stay running when off. - Honda-Tech
Old 10-19-2013, 08:21 AM   #1
Default Heater (vents) stay running when off.
I have done some research and found a few similar posts but no answer. i went to start my car one day to find it dead so i jumped it. later when i parked my car and turned it off, my fans stayed on as well as the little green lights that show my selection on on climate control. I disconnected the relay for the fans but the lights still stay on. Could this be an ignition problem? 1995 honda accord EX
qhiggy is offline   Reply With Quote
Old 10-19-2013, 08:24 AM   #2
Default Re: Heater (vents) stay running when off.
also when i turn my car off, i hear a click followed ny the fans powering on. unless i turn them off manually but they r still getting power.
Old 10-20-2013, 12:59 AM   #3
Is the car overheating at all ? Do the fans come on when they key is in the on position or while you're driving ?
Your fan timer unit could be bad.
I'm not sure about the climate control lights. I suppose it could be a relay stuck in the on position. Hopefully someone else knows.
holmesnmanny is offline   Reply With Quote
Old 10-21-2013, 07:10 PM   #4
Well its my fans on my dash that turn on wheb my cars off. If I leave my fan on or if I turn them on when my cars off, they woll come on. My car hasnt been over heating though.
Old 10-22-2013, 10:58 PM   #5
The fan(1 of them) that is in the dash is called a blower. If you call it a blower people will have a better idea of what you're talking about than if you call it a fan, which refers to those that are inside the engine bay.
I gotta be honest I'm not sure what would cause your issue. Hopefully someone else will have an idea.
Old 10-22-2013, 11:34 PM   #6
DeadlockRiff's Avatar
I have this issue as well, but I believe it has something to do with the harness. The issue originally would occur at random points in time. It has since stopped after I modified the center console to include wiring for packs of switches. This leading me to believe I've "rustled" the issue out so to speak.
It never bothered me enough to find it out, plus as long as you remember to turn it off, the car won't die. Despite the lights for the system remaining on.
DeadlockRiff is offline   Reply With Quote
Old 10-26-2013, 08:50 AM   #7
A stuck blower motor relay would allow power to go to the blower when the car is off.....
Lost Again is offline   Reply With Quote
Old 10-26-2013, 05:46 PM   #8
Granted, not saying that it couldn't be the OP's problem. Considering the relay is under the hood that wouldn't make sense in my case.
11 pilot cooling fan staying on wkobe88822 Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 0 11-16-2015 03:25 PM
A/C Fans Keep running after shutting down car Roniszoro Honda Accord (1990 - 2002) 0 08-26-2014 03:27 AM
93 Accord Fan stays on after shutting off. 93Accordman Tech / Misc 5 03-21-2014 06:25 AM
Radiator Fan Staying On When Car Off Dekorum Honda Civic / Del Sol (1992 - 2000) 10 05-02-2012 09:15 PM
Fans stay on after I turn my car off! Please help? Maddheadache Honda Civic / Del Sol (1992 - 2000) 12 01-27-2008 12:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
