f22b1 broken sensors
Old 10-21-2013, 03:48 PM
BDaTurboTeg's Avatar
Default f22b1 broken sensors
hey there everyone.
So I did a clutch for a friend on his 95 accord f22b1 motor. Everything went ok but we broke off 2 sensors under the distributor. We finished everything and its all good except the fans won't turn on.
Can anyone tell me what these sensors might be?
Just under the distributor, pass. side, on the head, just behind the thermostat. One is a plastic clip kind and the other just a push on kind. I wish I had a picture but I don't.
Old 10-21-2013, 03:49 PM
Default Re: f22b1 broken sensors
And the temp. gauge isn't working. It also started to overheat a bit
Old 10-21-2013, 08:53 PM
MM Gruppe B
MAD_MIKE's Avatar
There are a few themo switches and probes in that area, which ones?
The smaller metal one is the gauge, depending on which of the green connector ones were broken it may be the fan switch or the ECUs thermo sensor.
Old 10-23-2013, 11:35 AM
96odysseyjdmf22's Avatar
the 2 sensors under your distributor are as follows
The 2 wire sensor closer to the firewall is the ECT for your cars temperature
The 1 wire sensor is your ECT Sending Unit for your gauge (closer to the front of the car)
the other 2 sensors for coolant in the car are for the fans
1 of them is on the thermostat housing and the other is on the housing for the upper radiator hose
Old 10-26-2013, 12:55 PM
ok. we fixed those 2 sensors but the fans still wont work. Gonna check it out more tomorrow and hope that we find a simple stupid answer.
timaccord95
08-17-2011 04:08 PM
Goodbye My Love
05-10-2006 05:54 AM
311
04-19-2005 03:45 AM
HamiltonRex
10-06-2004 01:32 PM
Quick Reply: f22b1 broken sensors
