Heater Controls will not turn off
Old 02-29-2012, 04:13 AM
JerseyAccord's Avatar
Default Heater Controls will not turn off
I have a 96 accord with a 2000 H22 Euro-R swap. Recently I started having a power drain issue that I can't seem to cure. My heater controls will not turn off (also my blower motor). I've checked my fuses and replaced the heater blower relay with still no luck. I noticed my one fuse box says fuse for heater control relay, i pulled this fuse and the heater control continued to have power and I'm not sure if this goes to the heater blower relay I also replaced or not. This is frustrating....
Old 02-29-2012, 10:31 AM
StreetsideStig's Avatar
Default Re: Heater Controls will not turn off
Is the control cable disconnected from the valve?
Old 02-29-2012, 02:31 PM
I don't understand, what valve and where?
Old 03-01-2012, 05:05 AM
The heated coolant passes through a valve in the line between your engine and your heater core. The degree that this valve is open determines how hot your heater core gets. There's a push/pull cable that runs from the temperature **** in your dash to that valve. Take a look near the firewall for the coolant line leading into the cab. There should be a valve on it. If the cable isn't attached, this may be your problem. I had this trouble on my '90.
Old 03-01-2012, 06:00 AM
why would a cable driven valve have anything to do with why my heater controls refuse to turn off as well as the blower motor? and yes it is still connected because not only do I have resistance, but the temp does change when I move the ****
unfortunately for me its an electrical problem and my next stop is the resistor
Old 04-30-2012, 09:42 AM
.adam.'s Avatar
did you ever get this figured out? i am having the same problem as well....
Old 01-29-2013, 04:20 PM
I Love My 4 door's Avatar
bump i know its old but having same issue, heater and controls wont turn off even with key out of car
Old 12-16-2014, 11:55 AM
philsob's Avatar
Has anyone figured this out? I have same problem with my accord
Old 12-17-2014, 04:45 AM
holmesnmanny's Avatar
Normally its a bad climate control assembly. I would swap in another assembly from the junkyard.
thewrai6th
03-10-2016 04:24 PM
navcc
04-28-2013 01:33 PM
mayfly
12-10-2009 08:01 PM
jdmomar
10-26-2006 06:52 AM
Quick Reply: Heater Controls will not turn off
