headlight bulb replacement
Old 04-22-2016, 08:09 AM
berra_15's Avatar
Default headlight bulb replacement
hi, i have a 97 honda accord sedan ex, was wondering how I'm supposed to change out the passenger headlight bulb seeing as theres no room to get your hand in there to pull the bulb out. thanks!
Old 04-22-2016, 08:51 AM
coolswimmerjon's Avatar
Default Re: headlight bulb replacement
The coolant reservoir lifts straight up to make more room. If that isn't enough for you the air intake box is only held in by a couple 10mm bolts if I remember correctly.
Old 04-22-2016, 09:55 AM
berra_15's Avatar
ok thannks! do i need to disconnect anything so no fluids come out or am i fine to pop it straight out ?
Old 04-22-2016, 11:48 AM
just remove the cap and the entire reservoir can slide right out, no other connections.
Old 04-22-2016, 11:50 AM
berra_15's Avatar
awesome thanks!
06civicoolie
Honda Civic (2006 - 2015)
09-28-2007 08:45 PM
sdsviet
08-15-2004 01:54 PM
beantowncoupe
04-24-2003 11:50 AM
aaronic
09-19-2002 09:32 PM
Akshay
05-08-2002 11:22 AM
Quick Reply: headlight bulb replacement
