Head gasket leaking ALOT of oil??? - Honda-Tech
Old 04-03-2012, 06:42 PM   #1
Default Head gasket leaking ALOT of oil???
Ok the car(95 ex) runs good and has brand new valve cover gasket,But the garage says the oil leak is under the head Just behind the Timing belt cover. I thought it was the camshaft seal, but the timing belt (That was replaced about 2,000 miles ago)is dry and it is a pressure leak it pours out and pools in the "horn" that sticks out back there. My question is is there a oil passage right there in the head??? I am used to GM products so this is why I am asking Thanks Bob
bob441 is offline   Reply With Quote
Old 04-03-2012, 06:59 PM   #2
dglassmyer's Avatar
Default Re: Head gasket leaking ALOT of oil???
Well you are right to suspect the camshaft seal as that will cause pooling right in that casting depression.
Another possibility is hondabond or an rtv equivalent was not used when the new valve cover gasket was installed. Without some sort of additional sealant those cover gaskets will leak and pool just in the area you described.
When you say this is a "pressure leak" does that mean you can see oil leaking out under pressure?
I ask because while there are oil drainway passages through the head in that area, they are gravity drains only and not under pump pressure.
dglassmyer is offline   Reply With Quote
Old 04-03-2012, 08:22 PM   #3
I put another Valve cover gasket myself ,The one they put on WAS leaking ,I only put sealant in the corners of the recesses.but it is now leaking out lower than the valve cover,It looks like it is coming out from where the timing belt cover and head meet the car runs good NO oil in water or water in oil.I presumed it was under pressure because of the amount it leaks so it may not be under pressure.Is this a common spot for the head to leak oil??I just do not want to spend 600 vs 200 for a camshaft seal
Old 04-03-2012, 08:40 PM   #4
Dude you need to remove the timing belt cover and inspect the shaft seals, there are about half a dozen seals under there.
motojcf27 is offline   Reply With Quote
Old 04-03-2012, 08:45 PM   #5
ok will do tomorrow
Old 04-03-2012, 08:53 PM   #6
dglassmyer's Avatar
Quote:
Behind the upper timing belt cover, really, what are they then??
The camshaft seal is the only seal that would fail and leak oil.
I can say in my experience I have never had a head gasket being the cause of oil leaking in this location.
It can be difficult to determine if it is a leaking camshaft seal however.
The camshaft seal is actually behind two timing belt covers, the inner and outer, and the camshaft gear itself.
Old 04-05-2012, 01:15 PM   #7
It was leaking out of the head below the cam seal. We took the cover off and cleaned it off and started it and you could tell it was oozing out from under the head where the head meets the block straight behind the REAR riming cover and it was leaking alot and it did not leak until it ran for about 3 minutes.Is a fel pro gasket set ok to use ??The dealer is about 40 miles away. I know to get new bolts.
Old 04-10-2012, 06:44 AM   #8
well IT was the cam seal NOT the head gasket thanks guys it saved me alot of money
Old 04-10-2012, 06:53 AM   #9
Quote:
Many say it is super rare for a head gasket to leak oil.
motegicivic is offline   Reply With Quote
2001 Accord EXL-UL F23A4 Oil leak at valve cover gasket or head gasket Xene Honda Accord (1990 - 2002) 13 05-27-2015 04:20 PM
Ls/vtec oil leak E-PiLLs Hybrid / Engine Swaps 4 02-02-2013 06:55 PM
has anyone ever tightened a couple head bolts to fix oil leak? 91crx-jace Acura Integra 4 04-22-2012 05:36 PM
Please help with 92 Accord oil leak!!!!!! jackyaj Honda Accord (1990 - 2002) 3 10-23-2009 01:16 PM
oil leak ?? gabhatch Tech / Misc 3 02-15-2005 11:31 PM
Tags
back, built, gas, gasket, head, honda, ket, leak, leaking, oil, pouring, powered, products, sealant, valve, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
