hazard light problems - Honda-Tech
Old 02-26-2008, 05:14 PM   #1
davey5300's Avatar
Default hazard light problems
My 94 Accord Ex has a problem with the hazard lights.
when I turn them on, they will flash for a little while, then they will freeze. the lights will be on, but it's not flashing. It will flash again for a few seconds then it will stop again. then they will flash like once every so often, then they flash off, and won't flash anymore. if I turn them off and turn them back on, they just flash on. and when it's doing that, the directionals are the same. onece I've had the hazards off for a while, the directinals will work fine. Please help me for I need the hazards for work ( i deliver news papers, so I'm driving on the wrong side of the road.)
davey5300 is offline   Reply With Quote
Old 02-26-2008, 06:29 PM   #2
hondadude's Avatar
Default Re: hazard light problems (davey5300)
Hmmmm, strange days indeed
the hazards and the turn signal use the same flasher unit, so if the turn signals work normally and the hazards are the problem, I would be suspect that the hazard switch has a problem.
hondadude is offline   Reply With Quote
Old 02-27-2008, 07:56 AM   #3
Default Re: hazard light problems (hondadude)
Humm... I think it might be your flasher is getting weak. Try changing it with one from a junk yard and see what that does.
I had a flasher problem with my 93 Prelude. It might be different, but the more you read, the more you learn.
http://www.honda-tech.com/zerothread?id=1618020
professorman is offline   Reply With Quote
Old 02-27-2008, 10:17 AM   #4
davey5300's Avatar
Default Re: hazard light problems (professorman)
o.k I'll try that but 1 question: Where is the flasher module? I think I know where it is, but i'm not sure.
Old 02-27-2008, 10:25 AM   #5
billyrusa's Avatar
It is attached to the underdash fuse/relay box. Remove the driver's side kick panel, you will be able to find the fuse box. The flasher is integrated with other control circuits in an Integrated Control Unit. This ICU box is just above the fuses in the fuse box. Disconnect the wire connector to it and then you can unplug it from the fuse box.
billyrusa is offline   Reply With Quote
electrical lighting turn signal and hazard issues nycd5 Honda Accord (1990 - 2002) 3 12-28-2012 02:06 PM
EG passenger turn signal on constantly. Not flashing Bikes&Bowties Honda Civic / Del Sol (1992 - 2000) 1 02-12-2012 05:42 PM
DC4 front signal issues ... WTF is going on? DC4 Dave Acura Integra 3 05-26-2007 09:23 AM
'94 Accord LX - Flashing D4!! accord0494 Honda Accord (1990 - 2002) 8 07-22-2006 08:02 AM
Turn Signals/Emergency Lights Senbonzakura Acura Integra 3 01-18-2006 07:29 PM
Tags
1994, 90, accord, control, flashers, hazard, hazards, honda, integrated, light, ligth, problem, problems, switch, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
