hay 91 accord idles up and down - Honda-Tech
Old 03-21-2011, 12:25 AM   #1
Default hay 91 accord idles up and down
i have a 91 honda accord ex that idles up and down butwhen i take the # 21 vaccume line off it stops. can anyone tell me whats going on with my car
killerkali420 is offline   Reply With Quote
Old 03-21-2011, 05:21 AM   #2
nus_dogg's Avatar
Default Re: hay 91 accord idles up and down
When does it do it? When it's cold or running hot at nomral temp?
nus_dogg is offline   Reply With Quote
Old 03-21-2011, 03:54 PM   #3
all the time dosent matter on the temp
Old 03-21-2011, 09:24 PM   #4
tighten the idle air valvle scew up i had two different ones do the same thing and another one was the intake gasket it sounds the same
matrix9_11 is offline   Reply With Quote
Old 03-22-2011, 08:18 AM   #5
apparently, idle surging happens with any vacuum leak.
i once had to unbolt my egr valve and had to leave it on loose; i started and ran the car - it was surging.
it just so happens that the fast idle thermal valve tends to be the most common (naturally occurring, when cold) source of a leak on hondas, though that may not be the case here.
try to find out what the source of your vacuum leak is -what is vacumm line 21 hooked up to?- and fix it.
MC Slide Hammer is offline   Reply With Quote
91 Accord Idle problem. desertratt Honda Accord (1990 - 2002) 4 09-16-2011 12:35 AM
idle problem on my 96 McPhaty Honda Accord (1990 - 2002) 2 06-29-2010 07:04 AM
NEED HELP: 91 accord runs then tach bounce up and down then dies smkngsr Honda Accord (1990 - 2002) 9 01-31-2008 11:27 PM
Black Box Next to Battery ? squiggle Honda Accord (1990 - 2002) 4 04-09-2007 05:24 AM
93 Accord LX rough idle. in park the idle goes up and down 1500 to 2000 rpms. rillboss Honda Accord (1990 - 2002) 5 01-06-2005 08:16 AM
Tags
90, 91, 94, accord, cold, del, honda, hot, idel, idle, idles, idling, make, ran, revs, sol, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
