New accord owner driversside windows not working
Old 10-02-2012, 02:53 PM
blackccoupe's Avatar
Default New accord owner driversside windows not working
Hi i just bought a 96 accord lx sedan stick and neither driver side windows work ,pass side ones work but front pass window is real slow. I checked the underhood fuses there fine where else should i look or what should i try. Also my hood latch gets stuck when i open it i have to use a screwdriver to push the lever back down is there a fix for this .. any help is apprecited
Old 10-03-2012, 03:15 AM
Default Re: New accord owner driversside windows not working
Anyone
Old 10-03-2012, 04:16 AM
Fitz Williams's Avatar
The problem may be the weatherstrip gasket, even if it looks good.
Old 10-03-2012, 04:37 AM
I mean the power windows dont move at all on the driver side
Old 10-03-2012, 05:18 AM
Have you checked for power at the window motors? Pull the door panels and check for power with the switch plugged in.
Old 10-03-2012, 05:41 AM
Ill try that should i try a new window switch first?
Old 10-03-2012, 06:58 AM
Check for power before and after the switch (while holding the switch open). If you get it before and not after then it is the switch. If there is no power before the switch, then you will have to work your way up the wiring harness by trial and error.
Old 10-03-2012, 03:27 PM
Fixed the problem cleaned the contacts in the switch and the driver door motor was unplugged for some reason but i do have a bad left rear window motor.
Old 10-05-2012, 07:40 PM
redheadgearhead's Avatar
For your sticking latch,
Thoroughly clean it with brake cleaner. Rinse all residue. Lube with white lithium grease. Work latch until proper operation is achieved.
1nice96
12-30-2012 08:14 AM
motorsports_3
08-15-2010 12:25 PM
drew and not u
06-28-2008 06:56 PM
scooterguy
11-26-2005 02:35 PM
Quick Reply: New accord owner driversside windows not working
