H23a vtec Swap into a manual 6th gen Accord
Old 07-29-2012, 09:12 AM
hondaaccordf23's Avatar
Post H23a vtec Swap into a manual 6th gen Accord
This is how I did my Swap hope it helps
Keeping it simple
Engine Mounts:
ALL accord mounts from the 6th gen will be used.
The F23A1 transmission bolts up
A/C:
A/C from the 6th gen accord will bolt be use.
POWERSTEERING:
Still need to install, but what I’m planning on doing is getting 97+ P.S. bracket and using my old F23A1 crank pulley
WIRING:
Just find out where each plug goes and plug it in. I extended my crank wires from the old timing case to the Dizzy
Wire colors:
Black/Yellow - Black/Yellow
Black - Black
Blue - Blue
Green - Orange/Blue
Red - White/Blue
White - White
Yellow/Green - Yellow/Green
Yellow - Orange
Main/Stripe
AXLES:
ALL Accord Axles will be used including halfshaft.
ECU:
For startup I used my stock ECU, but I would not recommend running your car.
Then I used PCB ECU and everything works excepted my temp gauge doesn’t work so got fix that problem also I got it to start with put A15 wire to A16
Exhaust:
I got a 97+ H22 flex pipe
http://www.exhaustdistribution.net/s...DE-DUAL/Detail
Then cut the Accord straight pipe and attached a connector to the pipe to shorten the exhaust
The Prelude flex pipe is a little bit longer than the Accord
I brazed it but you can get it welded
Cluster:
98-99 Accord Temp. Gauge ran off of two sensors the ECT(two wiring plug) and Sending unit (single plug
00-22 Accord Temp. Gauge ran off of one sensor the ECT
- To get the gauge to work in the 00-02 accord you will need 98-99 Cluster and wiring harness or wiring in plug
Anything I missed sorry firefox crashed so had to write it again
Old 08-02-2012, 05:41 AM
andrew888's Avatar
Default Re: H23a vtec Swap into a manual 6th gen Accord
I recently bought the same h23a engine to do a swap but am a little unsure about the wiring up part. Did you use the H23a harness or f23?
Old 07-05-2014, 06:17 PM
cdnsigop's Avatar
How did you fix the temp gauge problem?
Keeping it simple
Engine Mounts:
A/C:
POWERSTEERING:
WIRING:
Wire colors:
Black - Black
Blue - Blue
Green - Orange/Blue
Red - White/Blue
White - White
Yellow - Orange
Main/Stripe
AXLES:
ECU:
Exhaust:
Old 07-13-2014, 08:28 PM
sorry haven't been on here for awhile
Old 07-13-2014, 08:29 PM
cdnsigop
What year accord do you have?
Old 07-13-2014, 08:31 PM
I used the f23 wiring harness.
What issues are you having with wiring?
Old 07-14-2014, 06:08 PM
cdnsigop's Avatar
Mine was a 2002, the coolant temp gauge didnt work. From my research, you either use a converter box (one the civic guys who run S2000 clusters use) or you switch to a 98-99 cluster.
Car is pretty much sold now, but thanks anyways!
Old 03-27-2017, 11:56 AM
h23a01's Avatar
Honda accord f23:
I'm doing the same thing with f23a swap to h23a dohc vtec blue top.
I have a few questions about the exhaust:
. when you state "97" are you referring to a 97 h22 flex pipe or is this a combination of 97 prelude and 97 accord welded together?
. would u happen to know the dimensions or could you give me some measurements on length of the down pipe needed?
. would it be a bad idea if I just ordered a h22a4 headers b/c that's what I've read in other forums that its compatible to the h23a?
Question about ecu
. I have an ecu that's exactly for the blue top but its for an automatic , is it possible to get that chip and tuned so that its for a manual transmission and can run motor?
Old 02-15-2018, 04:33 PM
Dsellers's Avatar
Keeping it simple
Engine Mounts:
A/C:
POWERSTEERING:
WIRING:
Wire colors:
Black - Black
Blue - Blue
Green - Orange/Blue
Red - White/Blue
White - White
Yellow - Orange
Main/Stripe
AXLES:
ECU:
Exhaust:
Exhaust Distribution
Cluster:
what is the wiring diagram for a four pin distributor if anyone know obd1 H22a distributor internal coil and a obd2b f23 four pin harness help
Old 02-16-2018, 11:03 AM
OTOKOTO-TSOI's Avatar
Hi there I got some issue on my 98 accord F23a1 Lx US version, I swapped an H23A automatic from HMO with incomplete engine harness cut plug but comes with PCF ecu. Everything is installed and I used the plug from the stock Lx f23a1 engine. I was starting it but it won’t prime the main relay for fuel and no crank. Is it because the key immobilizer? Can someone help me with this? Thank you. H23A swapped 98 Accord automatic
sipaboy
Honda CR-V & Element
19
11-25-2016 08:35 PM
hondaaccordf23
07-04-2012 03:28 PM
FrankencrxBHAM
08-08-2006 02:14 PM
LCplKAC
07-26-2005 08:11 PM
accord5speed
05-29-2002 02:52 PM
Quick Reply: H23a vtec Swap into a manual 6th gen Accord
