H23 vtec - Honda-Tech
H23 vtec
Old 05-14-2012, 10:59 PM   #1
Default H23 vtec
So I'm ordering an H23 Vtec from Hmotors tomorrow and was wondering if anyone has any advice or anything I should know about doing an h23 vtec engine swap in an 2000 Honda accord ex 2 door manual
I have a h22 swap guide in a 6th gen accord handy
know that it a basic bolt up etc...
ordering ecu with it so that's covered
anything I might need to know
hondaaccordf23 is offline   Reply With Quote
Old 05-15-2012, 05:26 AM   #2
H22_CB7_JAY's Avatar
Default Re: H23 vtec
Guess not lmao.
H22_CB7_JAY is offline   Reply With Quote
Old 05-15-2012, 07:11 PM   #3
LOL
Old 05-15-2012, 07:36 PM   #4
GhostAccord's Avatar
H22A4 - H23A VTEC IIRC it's the same swap info. Why not drop it in and let us know how it works out for you. There seem to be quite a few members that come in and ask the same question. Then it seems as though they ether never go threw with the swap or they just never post back to help out others with any info on how the swap went.
Seems as though these days this forum is comprised of more takers than givers. I'm sure no one will hold it against you. If you feel that it's not worth your time to share your experiences!
Good luck with the swap
GhostAccord is offline   Reply With Quote
Old 05-16-2012, 04:12 AM   #5
ok
I got a 92 Accord I just put a h23a, dohc vtec in, I am trying to use exsisting wire harness and ecu
I put a skunk intake with a 76mm throttle on, headers
using exsisting injectors and fuel rail
went from auto trans to manual
engine, harness, tranny, manifold,and exhuast all in and hanging good
swapped distributor housing for prelude housing, accord inturnals
cannot get car to stay running past rough idle
any suggestions
Damnnorske is offline   Reply With Quote
Old 05-16-2012, 05:24 PM   #6
halninek's Avatar
any ecu codes?
check timing, did you do the t-belt, water pump, tensioner before installing?
try another known-good ignition coil if possible, check spark plug gap (were they replaced?), check firing order
need more info especially any ecu codes to go any further...
halninek is offline   Reply With Quote
Old 05-16-2012, 08:01 PM   #7
GhostAccord I will post my swap when done. lol I just order engine today should be here around the 31st.
Old 05-17-2012, 12:29 AM   #8
Parties with 2LEM1
Brice.Hayden's Avatar
finally ordered a motor!! so many threads about this
Brice.Hayden is offline   Reply With Quote
Old 05-21-2012, 10:25 AM   #9
On my h23 swap
I now am installing a p28 ecu, have swapped out f22 injectors for the h23 injectors (obd2), bypassed the resister module for the f22 injectors, rebuilt distributor with correct gaps for sensors
Expect to have running this weekend if p28 is done being chipped
Old 06-21-2012, 07:39 PM   #10
HELP me with wiring harness please
Old 06-21-2012, 07:51 PM   #11
You should use the wiring harness originally from the car worst case scenario is you will have to extend a couple wires.
villc713 is offline   Reply With Quote
Old 06-21-2012, 08:18 PM   #12
mickyT's Avatar
for my h23a swap in a 5th gen, i used the h23a wiring harness.
if your dizzy is an external, be prepared to re-wire to a internal dizzy since the h23a dizzy is an internal dizzy.
mickyT is offline   Reply With Quote
Old 06-21-2012, 08:20 PM   #13
True but you have to remember some of these harness's that are shipped for these motor are or could be rhd instead of lhd harness's
Old 06-21-2012, 08:23 PM   #14
mickyT's Avatar
my harness was a RHD harness, i just had to extend them and made an adapter for the internal dizzy, just like the rywire one.
Old 06-21-2012, 08:33 PM   #15
Yeah I understand that but if his harness is still good why take it out? And about the external and internal coil part will be his decision. Internal is best tho.
Old 06-21-2012, 09:27 PM   #16
my H23 wires were cut in a couple of places one being the distributor
Posted from Honda-tech.com App for Android
Old 06-21-2012, 09:30 PM   #17
and what is the difference between internal and external
Old 06-22-2012, 04:49 AM   #18
DrJimmieRustles's Avatar
Internal and external what?
DrJimmieRustles is offline   Reply With Quote
Old 06-22-2012, 12:47 PM   #19
Internal means coil is inside the dizzy external means coil is outside of. Dizzy
Old 11-26-2012, 05:51 PM   #20
DOMO_EK6's Avatar
NEED HELP!!!!!!!!!!!!!! i got h23a vtec blue top and my o2 sensor got damaged from road rash and im having a hard time finding one to replace it the connector on the harness is a 3 wire and i dont know much about harnesses, also im running a p28 ecu plz help
DOMO_EK6 is offline   Reply With Quote
Old 11-27-2012, 12:06 AM   #21
You're not gonna find a 3 wire oxygen sensor for it, the best thing to do is to cut off a connector for 4 wire from a junkyard and buy some shielded wire off ebay and wire up your own. Remember, to cut back the metal shielded portion on the ecu side and put a butt connector on it, then put some wire on the other side and run it to ground. The signal wire for the oxygen sensor needs to be shielded. To find the correct pins, do a search for "obd1 pinout" to find out where to splice in your wires.
holmesnmanny is offline   Reply With Quote
Old 11-27-2012, 12:11 AM   #22
here's an example of something you need
http://www.ebay.com/itm/16-AWG-TEFLO...item19d6c3f143
H23 swap Sleeper91 Honda Accord (1990 - 2002) 8 04-18-2008 06:14 PM
Wiring help need with a H23 swap into 92 Accord accuder Honda Accord (1990 - 2002) 4 02-11-2007 08:08 PM
thermostat differences- H22/H23 BoostedH23a1 Honda Prelude 3 09-07-2005 01:26 PM
engine swaps accordsi23 Honda Accord (1990 - 2002) 1 03-16-2004 02:30 PM
Will F22 vtec distrib work on h22 or h23? BoostedH23a1 Honda Prelude 1 03-21-2003 08:08 PM
Tags
2002, accord, code, ecu, engine, h23, h23a, honda, swap, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
