H22 swap tranny ?
H22 swap tranny ?
I did a search and check the FAQ, but did not find an answer to my question.
As much as I like the H22 swap, the one thing that is starting to nag at me is how high the rpm's are at 70mph, over 3600 rpm and at 80, over 4000rpm. It feels like I should have a 6th gear.
So, my question is what other tranny will fit into the H22? I hope that whatever recommendations/suggestions there are, the tranny will be readily available and not break the bank.
Thanks in advance for all replies.
Mike
Mike
Re: H22 swap tranny ?
I have an H22 1st, 2nd, 3rd, 4th, and f series 5th in my accord. This can be done with modification, the 5th gears has to be shaved down a little thinner to fit. But it will give you good acceleration as well as a low rpm 5th gear! they have the same exact case just the location of the stud for the tranny mount is different which can be removed and put in the extra hole for the accord mount.
H22 tranny with F22 5th if I had to do it again.
