h22 swap has issues.
Old 08-18-2004, 02:12 PM
SirRevvs's Avatar
Default h22 swap has issues.
Alright so here's the problem. First of all we got a h22a1 obd1 out of a wrecked 94 accord. The accord was a friends and the engine ran beautifuuly in that car. So anyway now we sold the swap to a guy with a 96 accord(obd2). The engines in everything is hooked up right as far as we know we got a obd2-1 harness off ebay and switched the wires and added vtec all that good stuff. So this is what is happenning now. THe car starts but you have to give it gas or it will idle rough, stall, spin backwards, shoot air out the intkae and then finnaly die. Its also got check engine light but we tried plugging in diagnostics to read the code but we just get a blank screen its a jdm comp. We're also using the accord f22 map swrewed to the firewall with vaccuum hose going to the intake manifold where map plugs up. This is our first h22 install and we basically are out of ideas and have no where to begin troubleshooting. Any info/advise will be very much appreciated.
Old 08-18-2004, 02:36 PM
SirRevvs's Avatar
Default Re: h22 swap has issues. (SirRevvs)
anybody?
Old 08-18-2004, 02:46 PM
fastsohc's Avatar
post your question in hybrids. I am sure some one will know.
Old 08-18-2004, 02:50 PM
KTeller8's Avatar
Default Re: h22 swap has issues. (fastsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastsohc &raquo;</TD></TR><TR><TD CLASS="quote">post your question in hybrids. I am sure some one will know.</TD></TR></TABLE>
blah,
this is five speed right?
obd2 reader might not work, since you got the harness??
you check your idel scew? any vac or anything else leaking?
which ecu you running?
check the CEL via the jumping method..
Old 08-18-2004, 02:59 PM
SirRevvs's Avatar
Default Re: h22 swap has issues. (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">
blah,
check the CEL via the jumping method.. </TD></TR></TABLE>
converted to five speed via accord tranny
used reader with accord comp
don't know alot about accords or accord swaps where's idle screw, I believe its a p73 jdm comp for auto tranny, and the cel jumping method what's that?
Old 08-18-2004, 04:11 PM
SirRevvs's Avatar
bump
Old 08-18-2004, 04:21 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">
don't know alot about accords or accord swaps where's idle screw, I believe its a p73 jdm comp for auto tranny, and the cel jumping method what's that?</TD></TR></TABLE>
you lost me.. ok it was an auto? but you did the WHOLE auto to five speed change right???
Idle screw would be bove or really close to you throttle body~
Old 08-18-2004, 04:23 PM
SirRevvs's Avatar
yes we've already driven the car down the road it just won't idle
Old 08-18-2004, 04:27 PM
SirRevvs's Avatar
Idle screw would be bove or really close to you throttle body~</TD></TR></TABLE>
If it drives did we do the WHOLE changeover It's using a auto tranny computer but we have the same problem with the accord obd2 computer
Old 08-18-2004, 04:30 PM
KTeller8's Avatar
well you need to get off the automatic tranny ecu and put in the manuel h22 ecu
your ecu is telling the car to shift when your now five speed! the obd2 computer is both ecu and tcu!
if i get what your saying, that would help~
Old 08-18-2004, 04:32 PM
SirRevvs's Avatar
well we plugged up the f22 stock comp and the car was already manual. we're having problems with the car stalling it won't hold an idle other than that the car drives/runs
Old 08-18-2004, 04:33 PM
KTeller8's Avatar
you need to use a five speed tranny and computer..
distrubtor also if its obd2 self changes, going to obd1 would need to to be done manual, so you might need to check that dizzy and fix that~
Old 08-18-2004, 04:34 PM
SirRevvs's Avatar
also the engine is obd1 and the car is obd2 it won't idle with the obd2 accord comp or the obd1 h22 comp
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">well we plugged up the f22 stock comp and the car was already manual. we're having problems with the car stalling it won't hold an idle other than that the car drives/runs</TD></TR></TABLE>
f22 stock ecu is a sohc ecu..
your now running a dohc engine, which fuel, timing and other stuff all have changed. also there are more sensors and features with the h22 that you are having no control of with the f22 ecu. vaccum and secondary butterflies, etc.
if the car was already manual do not sure an automatic ecu~
Old 08-18-2004, 04:35 PM
SirRevvs's Avatar
the engine and h22 comp is obd1 and the car is obd2 and we've already done the obd2-1 changeover
Old 08-18-2004, 04:36 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">also the engine is obd1 and the car is obd2 it won't idle with the obd2 accord comp or the obd1 h22 comp</TD></TR></TABLE>
if the engine is obd1 you need to convert to obd1.
if its afive speed, you use the obd2-1 harness and make sure they switched the heater/egr two pins..
if its a basic obd2-1 harness that wasnt done! only accord and preludes have these wires switched.. all civic , tegs and everyone else dont.. so you got to make sure its done!
every harness we sell, we have to phsycally change them for the customer if they use a lude or accord.
Old 08-18-2004, 04:38 PM
KTeller8's Avatar
only thing i can say, is go look at your basic h22 swap write ups. make sure you didt it all and did it correcty
check the CEL for goodness sake, if the reader dont read it, then jump it with a wire and count the codes that way~
Old 08-18-2004, 04:39 PM
SirRevvs's Avatar
that's been done with the switching of wires why would the auto obd1 comp cause the engine not to idle
Old 08-18-2004, 04:41 PM
SirRevvs's Avatar
yea the whole situation is hard to explain i guess I just wan the car to idle and I need to know what to troubleshoot I've done extensive search and trial and error.
Old 08-18-2004, 04:42 PM
KTeller8's Avatar
you have xxx amount of sensors that are there and that ecu will not tell them to do anything
h22 has a lot more features/sensor on the motor, you AUTOMATIC accord ecu will not look for them, thus they dont do jack..
so the ecu is telling your motor to run off automatic timing and fuel curves specs..
all i am going to say from here on:
get the right ecu!
automatic ecu
get the ecu made for your motor
and CHECK YOUR CEL!!
Old 08-18-2004, 04:46 PM
SirRevvs's Avatar
I'm sorry if I confused you so I'll reexplain. It's a 1996 (obd2) accord lx with manual transmission. Installed was a 1994 jdm prelude motor (obd1) with auto tranny computer. we used the accord manual tranny on the h22 so what's in it right now is 1996 accord lx with 1994 h22 mounted to 1996 manual tranny running off of a 1994 prelude obd1 automatic transmission comp.
Old 08-18-2004, 04:51 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry if I confused you so I'll reexplain. It's a 1996 (obd2) accord lx with manual transmission. Installed was a 1994 jdm prelude motor (obd1) with auto tranny computer. we used the accord manual tranny on the h22 so what's in it right now is 1996 accord lx with 1994 h22 mounted to 1996 manual tranny running off of a 1994 prelude obd1 automatic transmission comp.</TD></TR></TABLE>
even worse.. the automatic tranny computer (TCU) only has 2 plugs.. you sure thats what your running?
automatic obd1 car has two computers
a ecu for the motor
a tcu for the tranny
obd2 car uses one ecu
it has both combined together..
your getting there.. still need more info~
Old 08-18-2004, 06:03 PM
RTFM
v4lu3s's Avatar
i suspect that the car is a 5spd and the ENGINE computer is from an auto prelude. which is NOT an issue.
you need to jumper to get the check engine light to flash, an OBD2 scan tool will nto work, so onc eyou can jumper and see the engine light flas i bet it will flash for code 12 and 41 at least. maybe more, but i would check the pinouts on the harness through the obd2-1 jumper since if it was built for a civic it wont cover things like egr systems usually. and even if it does the egr and o2 sensor heater on an accord is usually switchd as far as pins compared to every other honda too.
what you need to do first is check the codes though.
Old 08-18-2004, 06:29 PM
SirRevvs's Avatar
Default Re: (v4lu3s)
thankyou for finally understanding what my setup and problem was. I guess that checking the codes is really the best place to start I just am not sure how to "jumper an ecu"
Old 08-18-2004, 06:40 PM
RTFM
v4lu3s's Avatar
on an obd1 car you ahve a 2 pin jumper above the ecu behind the kick panel, i THINK some obd2 cars do as well. anyway if you have this blue 2 wire plug, you can put a piece of wire on the plug to connect it and count the flashes of the check engine light. I usually have ot hunt around on line and ifnd the 2 pins on teh obd2 diagnostic olug that you can connect and view the lights that way as well.
Quick Reply: h22 swap has issues.
